I'm a brand new forum member but I've been reading here for quite awhile. I bought a 30D in June and after reading just about every thread on the internet about tripods I bought a Gitzo GT2530 6x carbon fiber tripod two days ago. No buyer's remorse, I'm very satisfied with what my money (a lot of it) bought me. But there is one thing that doesn't live up to the advertising, unless I'm missing something essential, which is very possible. So I'm asking any Gitzo 6x owners or anyone familiar with them to help me out.
Ground Level Set is a new Gitzo feature that allows you to remove the center column and secure the ballhead attachment disk directly to the center column locking collar. It's very easy to do and makes a very stable and secure platform. In its catalog and on the website Gitzo makes two claims for GLS, it reduces weight and it makes "ground level photography" (their words) possible. And to illustrate the ground level capability the catalog, website and the tag that is attached to the tripod have a drawing that clearly shows the tripod legs at a low angle with the tripod center a few inches off the ground.
The weight reduction is why I was primarily interested in GLS since the height of the tripod with the center column unextended is perfect for me. But ground level ability was an attractive feature if I ever decided to pursue macro and it was a factor in my decision to spend my money on the latest generation Gitzo instead of a cheaper competitor.
After playing around with the 2530 for several hours it seems to me that Ground Level Set doesn't make ground level photography possible. After thouroughly reading and implementing the instructions that came with the tripod I've observed the following:
1. The instructions state there are three tripod leg angles: 24, 60 and 80 degrees.
2. At the 60 degree stop with the legs retracted, the center column only has to be raised 3/16 of an inch to keep it from touching the ground. So I can use the tripod with the center column or without the center column equally well at this setting. GLS doesn't seem to be an advantage here.
3. The 80 degree stop is really 90 degrees as far as I can tell. But no matter what the actual angle is, at this stop with GLS implemented the bottom part of the metal collar that holds the center column touches the ground first, leaving the legs wobbling off the ground. This is clearly useless for photography.
4. Putting the legs at an angle between stops doesn't make a stable setup. The weight of the camera and ballhead push the legs down to the next leg stop.
So the 60 degree leg stop works equally well with or without GLS and the 80/90 degree leg stop is useless even with GLS. Where exactly is the "ground level photography" ability that GLS allows which is illustrated in the drawing that accompanies all of the advertising? And what is the point of the 80 degree leg stop if it makes the tripod completely unstable?
Thanks for any comments or enlightenment. Now for the ballhead, Markins, Kirk, RRS, Acratech, AS.........
