Thread started 15 Sep 2007 (Saturday) 14:46
Lightening Eyes
Angry ­ Dad
Sep 15, 2007 14:46 |  #1
Hi all,
I admit Im an extreme newbie. I need help lightining the whites of my wifes eyes. Is there a quick way to do this? I tried Dodging the whites up, but I didnt like it so much. Any help is appreciated.
www.tembophotography.c​omCanon 5DmkII, Canon 70-200mm 2.8L II Canon 35mm 1.4L Canon 24-105L Sigma 50mm 1.4 EX and a bunch of other crap. (external link)
poloman
Sep 15, 2007 21:22 |  #2
Dodging is the way to do it. I use about 17 to 20 percent opacity and a soft brush. Some of the brushes have the same density out to the edge and some soften around the edges. The softer ones will blend better. Be careful not to lighten too much. You can use this under the eyebrows too to make the eyes look bigger. Also helps with teeth. If you go too far with the whites of the eyes, it will look unnatural.
Hope I helped. :)
"All those who believe in psychokinesis, raise my right hand!" Steven Wright
ST77
Sep 15, 2007 21:49 |  #3
I create a new adjustment layer, change it from normal to screen, alt+backspace to turn in black paint over the whites with a soft brush and then adjust the opacity down to around 15-25%
My Gear: 1D Mark III,30D, 24-105 f/4L IS, 70-200 f/2.8L IS, 85mm 1.8, 100mm 2.8 Macro, 580ex II Flash 430ex Flash lowepro AW 300.
My spot on the web: www.st-77photo.com (external link)
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Sep 16, 2007 10:23 |  #4
Id try the Layer> Adjustment Layer / brightness-Contrast first. Sometimes just reducing the saturation is also enough.
Exposure, car lighting, layer Masks, selecting ALL in here:
See post #9; PS Elements in Post # 14
A question about sky
Angry ­ Dad
Sep 16, 2007 12:06 as a reply to  @ PhotosGuy's post |  #5
Well I went and re tried the Dodge tool. I did get the eyes whiter, but Im still confused about new layer level. When I click new layer adjustment, I have to choose an option. I just skipped that part and did it on my original.
PhotosGuy
Joined Feb 2004
Sep 16, 2007 12:18 |  #6
Yes. Several tools have a mask built in.
...and did it on my original.
BAD choice! Someday, when you know more, you may want to revisit that file. At the very least, you should make a dupe layer & only work on that. This will double your file size, where using an Adj Layer will not.
1,550 views & 0 likes for this thread, 4 members have posted to it.
Lightening Eyes
494 guests, 158 members online
