SilverOnemi wrote in post #3941153
lol i will post this for the 3rd time
evrey single focus point is cross type, honestly this focus point appears to be larger than the others, it's actually bigger than that little box on the view finder, also imagine that you had this hot babe infront of you, and you wanted to focus her eyes instead of her nose, and you had an aperture of 1.2. how would you handle this with your 40D.
it would focus on her nose instead of eyes since nose is mostly big and bright item, so her eyes would be OOF.
you can find more information here, with farrukh threat :
https://photography-on-the.net/forum/...=376605&page=6ofcourse it works on large targets, there for i do not call it high precision.
i know i'm getting slightly off topic here, but i'd like to see some 40D testing about this and warn users about it.
I think maybe you might be a little confused. The AF sensors are designed to "lock" in on high contrast targets. Between the nose and the eyes, I think the eyes would be considered much more high contrast than the nose would be.
Also, the precision is not determined by how large, or rather how long, the focusing sensor is. If if were, the 1D series camera would be doing worse as far as focusing is concerned than the xxD cameras. The size only determines how much of an area will be considered when looking for any high contrasts target. Whether an AF point is high precision or not is determined by how far apart the AF sensor pairs are placed from each other. Didn't know there were two AF sensors used for each AF point, did you?
The farther apart the AF sensor pairs are from each other, the more accurate the focusing will be. That is the reason high precision AF sensors requires a lens with an aperture of f/2.8 or wider. Lenses with smaller apertures don't allow the AF sensor pair to be spaced as far apart as f/2.8 lenses do.
Below is a diagram of the 40D sensor which I pulled from the 40D white paper.
I circled the AF pairs in different color. The blue and green sensors are the sensor pairs that work with f/2.8 or wider. The ones in red are the sensor pair for the center vertical-line sensitive AF sensor that works with f/5.6 and wider. If you look over the other sensors, you should be able to find each AF pair for the different AF points.
