Thread started 17 Sep 2007 (Monday) 02:29
ISO When to?
ejlkicks
Sep 17, 2007 02:29 |  #1
Hey folks,
Is there a thread or a site that tells you a list of things you should know about ISO?
Like what ISO to use depending on the setting?
I learned that in dark settings i should use like ISO 1600?
Or maybe you folks can list them? Thanks alot. Sorry, still learning
Flickr!
http://flickr.com/phot​os/eddddyyyy (external link)
sando
Sep 17, 2007 02:57 |  #2
Its just the basics of exposure.
There can be many different combinations that give exactly the same exposure, you just need to learn what combination to use to produce the result you want.
- Matt
krepta
I swear I'm Ken Rockwell!
Sep 17, 2007 02:57 |  #3
More experienced users will be able to give you a more detailed answer, but the basics are as follows:
Higher ISO number means more sensitivity to light. Thus, when there is little available light, you should use a higher ISO. High ISO's are also used to capture fast action (i.e. "freeze" the action), such as in sports photography.
Alex | flickr (external link) | Gear & Feedback | Food! (external link)
Deckham
Sep 17, 2007 03:01 as a reply to  @ krepta's post |  #4
Higher ISO= more light to the sensor = faster shutter speeds possible = smaller aperture possible = greater DoF
Higher ISO also = more 'noise'
Wider aperture = lower ISO possible = less noise = faster shutter speed possible
Wider aperture also = less DoF
Find the best combination for your shot :)
Lulu Clake (external link)
Zenfolio  (external link)
Jim ­ G
I feel thoroughly satisfied
Joined Jun 2005
Sep 17, 2007 03:11 |  #5
Whenever I can't get a shutter speed high enough for what I want I up the ISO.
e.g. if it's dark and ISO 400 is giving me 1/20 shutter speed at maximum aperture and I need, say, 1/80 to get a shake-free shot... time to up the ISO to 1600! 1/80s is mine! Bwahahaha.
Gear Listhttp://www.codastudios​.com.au (external link) Reviews & Hotlinks: Domke F-3x - Pelican 1510/1514 (external link) & 1610/1614 (external link) - DIY Variable Length OC-E3 - Crumpler 6 Million Dollar Home (external link) - FA-100 (external link)
rowdyred94
Sep 17, 2007 08:32 |  #6
Deckham mentioned the increased noise. You should always use the lowest ISO that allows the shutter speed you need, unless you want noise for a particular effect. It's really that simple.
~ Clint :: Galleries (external link) ::
Deckham
Sep 17, 2007 09:44 |  #7
rowdyred94 wrote in post #3946906 (external link)
(and add DoF requirement) :)
nicksan
Man I Like to Fart
Sep 17, 2007 12:42 as a reply to  @ Deckham's post |  #8
I only boost the ISO only when necessary.
And the only time necessary is when I need the extra stop to use faster shutter speeds...
No rules for me. Always depends on the amount of light I am getting.
dustyporch
Sep 17, 2007 12:51 as a reply to  @ nicksan's post |  #9
My strategy is this. First, I generally find that ISO 400 is good for indoors, and 100/200 is good for outdoors. I use these as my starting point.
I generally shoot Av mode, so depending on the DOF requirements, I set the aperture. Then I check the exposure to see what shutter speed is required.
Now if the shutter is too slow, I bump the ISO up until the SS is better.
As a last step, I take a few test shots, and use EC to get the histogram right (no blown highlights).
I know it sounds like lots of steps... but it only takes a few seconds with practice. My point was that ISO is the 3rd item to set in the exposure triangle. Noise isn't good, but its better than motion blur or too shallow DOF.
My photos on Flickr... (external link)
krepta
Sep 17, 2007 20:48 |  #10
dustyporch wrote in post #3948444 (external link)
Hehe, this is the exact same strategy that I use. I always start with 400 indoors and adjust to higher ISO as required.
Deckham
Sep 18, 2007 04:20 as a reply to  @ krepta's post |  #11
Also exactly what I do - I think we're developing a theme here ;)
vic6string
Sep 18, 2007 07:20 |  #12
This question is easy if you don't use Canon DSLRs: Use ISO 100-400 only because everything else is horrible. Of course, since you are on this site, I assume you are using a Canon, and that means all ISO's are usable. Go spend a couple of hours on this site:
http://web.canon.jp/im​aging/enjoydslr/index.​html (external link)
It is a great little tutorial on the basics of photography. Once you have gone through it once or twice, and start playing with a DSLR in your hands, it all becomes alot easier.
Rebel XTi, 430ex, Tammy 28-75, nifty fifty, kit lens, tons of reading, not enough practice, and two gorgeous subjects (my kiddies)
Andy_T
Joined Jan 2003
Sep 18, 2007 07:36 |  #13
Similar here ... 400 or 800 (dark overcast days) as standard setting, more if needed.
ISO 3200 + 1EV underexposing + f/1.4 + 1/15 second (without IS) if it has to be to get the image.
You can always use noise correction afterwards.
Best regards,
Andy
some cameras, some lenses,
and still a lot of things to learn...
(so post processing examples on my images are welcome :D)
If you like the forum, vote for it where it really counts!
CLICK here for the EOS FAQ
CLICK here for the Post Processing FAQ
CLICK here to understand a bit more about BOKEH
basroil
Sep 18, 2007 09:23 |  #14
it really does depend on the situation, but generally you want just high enough iso to stop the important subject. i generally shoot higher, but i can afford to do that since a) newspapers have low quality b) mkiii's iso levels are beyond anything my xt could have hoped for
pdqgp
Joined Oct 2003
Sep 18, 2007 09:47 |  #15
My rule is to use the lowest ISO I can in order to get the proper shutter speed for my situation. Don't be afraid of higher ISO as noise will not show as much in prints as you'll see on screen. It will be masked even more if you get your prints from a lab.
1,776 views & 0 likes for this thread, 13 members have posted to it.
ISO When to?
2699 guests, 167 members online
