Thread started 17 Sep 2007 (Monday) 04:04
40 d problems
JuStDaVe
Joined May 2004
Sep 17, 2007 04:04 |  #1
I have a 40d first one i got colours were flat and lifeless canon replaced
second one i got colour was ok but the reds were stuffed and came outmore of a pink and auto focus issues
i know 3 ppl with 40d and the same issues reds are out and the autofocus is ****
any one else having these issues ?
1dmk3, 1dmk4 - 2 x 70-200 f2.8 IS, 16-35 f2.8, 17-40 f4, 300mm 2.8, 28-80 f2.8, Cybersyncs, 2 x 580 ex2
Robkat
Sep 17, 2007 04:07 |  #2
I have a 40d and no problems at all so far.
:)Canon 40d, 20d, 70-200 is, 24-105 is, Sigmas 10-20mm
"As long as you derive inner help and comfort from anything, get it"
BogongBreeze
Sep 17, 2007 04:08 |  #3
Nope. Mine has great and very true colour and autofocus is blazing fast and accurate. Pics have never seemed so sharp.
Sorry to hear that you are having problems. Can you post any pics with exif for comparison? Are you shooting raw or jpeg? And if jpeg, what picture settings do you use?
Miriam
Canon 90D and various lenses
JuStDaVe
Joined May 2004
Sep 17, 2007 04:11 |  #4
nah shooting jpeg there is an issue there have spoke to canon rep about the first one but yeah the reds is a bit of an issue
BogongBreeze
Sep 17, 2007 04:25 |  #5
JuStDaVe wrote in post #3945918 (external link)
Is the colour a problem for printing or viewing on the web? If viewing on your computer, what program are you using (and is your monitor calibrated).
Colour is such a complex area. Having said that, Canon reds have been reported as being problematic at times (from other camera models), depending on the colour space.
So far though, I've found the 40D quite good for colour across the range. But I haven't done any testing (and likely won't).
A couple of things you might want to try. Switch between sRGB and Adobe RGB and see if you like the results from one better than the other (not for the web, just use sRGB for that). Also, you could try different picture styles or altering the styles in the camera and see if that helps.
Miriam
JuStDaVe
Joined May 2004
Sep 17, 2007 04:50 |  #6
i might try adobe rgb .... but i use a crt for the pure reason that i am fussy with colours.
just a shame cos it seems ok other than that
tzalman
Fatal attraction.
Sep 17, 2007 05:15 |  #7
BogongBreeze wrote in post #3945947 (external link)
Differences between sRGB and AdobeRGB would be visible (perhaps) only in a print. With a calibrated monitor and viewed in a color managed application they should look exactly the same.
Elie / אלי
Lord_Malone
Cream of the Manpanties.....​... Inventor Great POTN Photo Book
Sep 17, 2007 05:36 |  #8
The only "red" issue I'm having with my 40D is the tiny red hot pixel in the lower left corner of the LCD. Other than that my pictures are turning out quite... picture perfect. ;)
BTW, I use aRGB and shoot RAW+Neutral.
You and your friends should post some samples so we can check it out.
~Spaceships Don't Come Equipped With Rear View Mirrors~
http://www.myspace.com​/chocolate_thai (external link)
John_B
Gallery: 178 photos
Sep 17, 2007 06:01 |  #9
JuStDaVe,
I have been very happy with mine. AF is even better then my 5D and color seems to be pretty darn accurate on par with my 5D (with jpeg & raw).
click to see (external link)
Lord_Malone
Sep 17, 2007 06:04 |  #10
I just thought of something. Not to insult your intelligence as I'm sure you know how to handle your gear, but could you by chance have maybe inadvertently adjusted the white balance correction [WB SHIFT/BKT], shifted over to the magenta zone and not have realized it? Might be worth a look. If it still reads "0" across the board have you tried using the WB correction feature to compensate?
JuStDaVe
Joined May 2004
Sep 17, 2007 06:51 |  #11
every other colour is spot on so i dont think its the white balance
sandro9mm
Sep 17, 2007 06:56 |  #12
sample images?
Photography Tips (external link) - Learn photography now!
Famous photographers (external link) - Video Interviews, photos, biography
My gear (external link)
Lord_Malone
Sep 17, 2007 08:29 |  #13
Show us some samples.
bsmotril
Gallery: 11 photos
Joined Feb 2006
Sep 17, 2007 09:53 |  #14
Red's look OK to me. ISO 1250 with highlight tone priority and high ISO noise reduction enabled. Unprocessed JPEG right from the camera.
IMAGE: http://farm2.static.flickr.com/1222/1333044065_d2f5c31da9.jpg
rientation: Horizontal (normal)
X-Resolution: 72 dpi
Y-Resolution: 72 dpi
Date and Time: 2007:09:05 21:01:28
YCbCr Positioning: Co-Sited
Exposure Program: Manual
Date and Time (Original): 2007:09:05 21:01:28
Date and Time (Digitized): 2007:09:05 21:01:28
Shutter Speed: 499712/65536
Metering Mode: Partial
Sub-Second Time: 36
Sub-Second Time (Original): 36
Sub-Second Time (Digitized): 36
Color Space: sRGB
Focal Plane X-Resolution: 2210.046 dpi
Focal Plane Y-Resolution: 2209.262 dpi
Exposure Mode: Manual
Compression: JPEG
Image Type: Canon EOS 40D
Owner Name: xxxxxxxx
Camera Serial Number: xxxxxxxx
Model ID: 2147484048
Tag::Canon::0x0013: 0, 159, 7, 112
Tag::Canon::0x0026: 96, 2, 9, 9, 1936, 1288, 3888, 2592, 97, 97, 97, 97, 97, 97, 97, 97, 97, 98, 98, 98, 98, 98, 98, 98, 98, 98, 0, 64887, 649, 64502, 0, 1034, 64887, 649, 0, 562, 298, 298, 0, 0, 0, 65238, 65238, 64974, 16, 16, 0, 65535
Tag::Canon::0x0028: 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
Lens Type: EF70-200mm f/2.8L IS USM
Internal Serial Number: J0012522
Tag::Canon::0x0098: 8, 8, 8, 8
Tag::Canon::0x0099: 356, 4, 1, 92, 7, 257, 1, 0, 258, 1, 0, 259, 1, 1, 260, 1, 0, 261, 1, 0, 264, 1, 0, 271, 1, 0, 2, 44, 3, 513, 1, 1, 514, 1, 1, 515, 1, 1, 3, 92, 7, 1285, 1, 1, 1286, 1, 4, 1295, 1, 1, 1296, 1, 0, 1294, 1, 0, 1297, 1, 0, 1551, 1, 0, 4, 104, 8, 1793, 1, 2, 1794, 1, 0, 1796, 1, 4, 1798, 1, 0, 2059, 1, 0, 2063, 1, 0, 2064, 1, 1, 2062, 1, 0
Tag::Canon::0x009A: 0, 1936, 1288, 0, 0
Tag::Canon::0x00AA: 12, 590, 1024, 1024, 439, 0
Color Space: 1
Tag::Canon::0x4008: 129, 129, 129
Tag::Canon::0x4009: 0, 0, 0
Image Width: 1936 pixels
Image Height: 1288 pixels
Macro Mode: Normal
Image Quality: Fine
Canon Flash Mode: External flash
Continuous Drive: Continuous, Low
Focus Mode: AI Servo AF
Canon Image Size: Small
Easy Mode: Manual
Focus Range: Not Known
Canon Exposure Mode: Manual
Lens Type: Canon EF 70-200mm f/2.8L IS USM
Lens: 70 - 200mm
Max Aperture: 96
Min Aperture: 320
Color Tone: 0
Scaled Focal Length: 200
Focal Plane Size: 45153 x 7184
Flash Guide Number: 16711696
ISO: 1269.9208415746
Measured LV: 65484
Target Aperture: 20.158736798318
Target Exposure Time: 0.0049215666011518
Flash Guide Number: 2047.96875
Flash Exposure Compensation: 2047.6666666667
F Number: 3.6
Camera Type: EOS High-end
Raw Jpg Size: Large
Color Temperature: 5200°K
Picture Style: User Def. 1
Sensor Width: 3944 (40-3927 used)
Sensor Height: 2622 (23-2614 used)
IMAGE: http://farm2.static.flickr.com/1398/1333116321_6e600b3365.jpg
Galleries: http://www.flickr.com/​photos/smopho/ (external link) --- http://billsmotrilla.z​enfolio.com/ (external link)
KarlMarsh
Living in a Marshist regime
Sep 17, 2007 13:22 |  #15
bsmotril wrote in post #3947313 (external link)
What software do you use to capture all that EXIF data?
Karl
Gallery (external link) Smugmug
Gallery (external link) Flickr
6,200 views & 0 likes for this thread, 20 members have posted to it.
40 d problems
2848 guests, 167 members online
