Thread started 17 Sep 2007 (Monday) 07:55
40D Spot Metering Query
goatee
"nice but dim"
Sep 17, 2007 07:55 |  #1
I've read through the manual, and can't find a way to do this, but. . . is it possible to have metering on evaluative, but have the * button activate spot metering?
Normally I want evaluative metering, but for occasions when I want spot, it's a pain to switch to spot metering, and then back again.
D7100, 50mm f/1.8, 18-140mm f/3.5-5.6, 70-300mm f/3.5-5.6 VR, SB800
https://photography-on-the.net/forum/showthre​ad.php?t=552906flickr (external link)
EOSAddict
Book Committee Immortal
Sep 17, 2007 07:56 |  #2
No, have to set using top switch and wheel (assuming same as 30D)
Al
My Gear, My Website: www.endofthetrailphoto​graphy.com (external link)
goatee
"nice but dim"
Sep 17, 2007 07:57 |  #3
:evil: that's irritating- is it such an unusual request to want to be able to do that?
Az2Africa
Sep 17, 2007 08:08 |  #4
It's a 2 second press and turn. What's hard about that? How did you want to be able to do it? Even if you set up one of the custom user setting, you would have to hit MENU and select it.
"If you're not living on the edge. You're taking up too much room !"
My Gear Arizona's POTN Flickr Gallery (external link)
Ronald ­ S. ­ Jr.
Prodigal "Brick" Layer
Gallery: 12 photos
Sep 17, 2007 08:10 |  #5
I don't even look when I do it. I just press the top right button, two clicks of the front wheel. That's it. Same thing to get it back, just the other way.
Mac users swear by their computers. PC users swear at theirs.
Crosswind81
Sep 17, 2007 08:21 as a reply to  @ Ronald S. Jr.'s post |  #6
I am new to photography and have yet to read anything educational on the practical difference between the different types of "metering". Can someone lay it out for someone who isn't really sure what it is and what it does for my pictures? Thanks in advance...:)
Rodney
Canon 40D/28-135 mm IS USM
100 mm Macro
70-200 2.8L IS
Speedlite 580 EX II/Sto-Fen Omni Bounce
IMac w/Aperture
goatee
"nice but dim"
Sep 17, 2007 08:30 |  #7
Ronald S. Jr. wrote in post #3946778 (external link)
Fair enough - I'll give it a go :D
Crosswind81 wrote in post #3946840 (external link)
VERY basically (so please excuse any errors from over-simplifying)
Evaluative means the camera analyses the scene as a whole and works out the best exposure.
Centre weighted - it looks at the scene, but pays most emphasis on what's in the centre, and a little attention to what's further out.
Spot - based on only a small area (spot) in the middle of the scene - on 30D and 40D there's a small circle in the viewfinder that is covered by the spot, and ignores everything else.
Partial - same as spot, but the area it looks at is 3 times the size of that used in spot metering.
Hope that helps :D.
avan
Sep 17, 2007 16:39 |  #8
with the 40D it's easy. Register your favorite set up (like AV, single shot, continuous H, 200 ISO, etc...) with spot metering in C1, C2 or C3. so when you need the spot metering instead of the evaluative, just turn the top dial to Cx where you have registred your alternative set up. I use this fonction for mirror lock up, etc...
I'm not sure but I think the * or AE-L button take a reading like a spot metering even if you are in evaluative and this is even easier and intuitive to use.
1DMK4, T6s, 100-400mmL IS II, 16-35mm f4, 100mm macro
[www.pbase.com/jeelee/g​alleries (external link)
1,691 views & 0 likes for this thread, 6 members have posted to it.
2706 guests, 166 members online
