Does the S3IS have the date stamp function? I' can't seem to find that function if any in the manual.
mrdgzpm Hatchling 1 post Joined Sep 2007 Location: Buckeye, AZ More info | Sep 17, 2007 21:14 | #1 Does the S3IS have the date stamp function? I' can't seem to find that function if any in the manual.
LotsToLearn Goldmember 2,290 posts Joined Mar 2007 Location: GTA, Canada More info | Sep 18, 2007 05:25 | #2 To be put on the image? No. You have to do it in software after/while downloading to pc.
rpolitsr Cream of the Crop More info | Sep 18, 2007 10:10 | #3 You can print the date using direct print compatible printers.
No further references to the [Date Stamp] function on the S3 IS or S5 IS manuals were found. rafael
LotsToLearn Goldmember 2,290 posts Joined Mar 2007 Location: GTA, Canada More info | Sep 18, 2007 10:36 | #4 rpolitsr wrote in post #3955765 On pg. 114 there is a note that stumped me though: No further references to the [Date Stamp] function on the S3 IS or S5 IS manuals were found. Because there are actually a couple of Canon P&S that do offer the date on the image. I think a couple of the smaller S models. It's part of a "Postcard" setting or something like that. But that's not available on the Sx IS series.
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Sep 18, 2007 10:46 | #5 I believe that the DPOF section is referring to Date Stamp which is only available in Postcard Mode on some other PowerShot cameras. The text wasn't edited for the S3 manual. So, no, you can't embed the date visibly in the photo at the moment you take it. You can later embed it in the picture via an action in PhotoShop, for instance, or manually. Jon
rpolitsr Cream of the Crop More info | Sep 18, 2007 13:04 | #6 LotsToLearn and Jon you are perfectly clear about the postcard setting possible in other cameras that embed the date in the file and that the S3 IS does not have. rafael
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Sep 19, 2007 10:50 | #7 Date On/Off functionality is enabled as part of the printer's firmware; all the camera setting does is pass along that it's needed. Jon
provobis Hatchling 1 post Joined Apr 2008 More info | Apr 05, 2008 08:03 | #8 mrdgpzm, this is a bit late in coming, but maybe it will help someone else with the same (current) question. First, in the S3IS manual rpolitsr has it right to set the print settings to print date (page 113). Once that is done the date is available to the camera software (Easy-PhotoPrint) which you bring up after installing on your computer. On the layout/print tab you can click the date tab below and the date will appear at any place, size or color you choose, and you can click file-preferences and you will see the choice there for the date configuration which remains until you unclick the date tab in layout/print.
| Latest registered member was a spammer, and banned as such! 1799 guests, 118 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
