I've seen this touched on, but I'm still puzzling over it. I'm using an ST-E2 to trigger a 550ex main and a 420ex fill... as well as a background strobe and hairlight monolight. I have the 550ex set on manual so the ETTL doesn't fire a preflash. However... I believe that there's still some sort of preflash going on because when I did a test of this setup without the flashes (and had just the background and hair light on), they were firing, but the picture came out black. I expected to see some light from these strobes in the picture. I've also done tests with the flashes -- both with and without the background/hair lights on and see absolutely no difference in the lighting.
I've poured over the ST-E2 manual, but it only talks about ETTL--- there's no mention of using this with the 550 in manual mode. Is there another way to disable the preflash?
This whole thing is driving me crazy. I'm about ready to scrap the use of the 550/420 for portrait lighting in my home studio and go with strobes. But, I already have the flashes, so I'd really like to get this set up to work, if it's possible. Any help or suggestions on this would be much appreciated!
