Memory card use and white balance and effect features should NOT be related one way or other.
You likely inadvertantly changed a setting without knowledge of it, or your camera is defective (somehow.)
Does it do it repeatedly. That is if you have 299 megs on the card, and shoot a few pictures, does it suddenly turn off AWB? Then does it turn back on again after you delete a few pictures to get back below the magic 300 meg mark. Only to have AWB again fail after you shoot a few more pictures?
If you can repeat the problem, the camera is flawed so take it back. If it can't be repeated, then likely a setting was changed without you knowing it.
