The only reason I'd upgrade to a 40D from my new-ish 30D would be if ISO1600 and 3200 were cleaner.
So, what's the fact when it comes to a comparison?
sando Goldmember 2,868 posts Joined Apr 2006 More info | Sep 20, 2007 02:04 | #1 The only reason I'd upgrade to a 40D from my new-ish 30D would be if ISO1600 and 3200 were cleaner. - Matt
MikeI Goldmember 2,074 posts Likes: 1 Joined Dec 2006 Location: NorCal More info | Sep 20, 2007 02:36 | #2 If that is the only reason you would upgrade, then the 40D may not be for you. I saw a review somewhere that summarized the noise difference was hardly noticeable if at all. Doubleshot Photography
MaDProFF Goldmember 4,369 posts Likes: 2 Joined May 2007 Location: East Sussex, UK More info | Sep 20, 2007 03:49 | #3 In my books, the 40D noise is a faction less, if you hit all the correct settings, if you don't, it is gets progressively slightly worse was than the 30D, as I posted before I think you have less tolerance to getting it right on a 40D. all with in reason ofc Photographic Images on Brett Butler
Sep 20, 2007 04:03 | #4 Exactly. The other features of the 40D don't interest me and as far as I'm concerned it isn't worth upgrading from a 30D. But, to me, IQ is paramount so if the noise-handling was better than the, alreday excellent, 30D then it's be worth it. - Matt
KeithR Goldmember 2,856 posts Likes: 1 Joined Aug 2006 Location: Blyth, Northumberland, NE England More info | Sep 20, 2007 04:41 | #5 What I'm finding is that between 400 and 1600 the 40D is clearly better than the 30D and chroma noise is virtually non existent.
MaDProFF Goldmember 4,369 posts Likes: 2 Joined May 2007 Location: East Sussex, UK More info | Sep 20, 2007 04:46 | #6 Though Sando, if ISO noise is your main interest, means you are shooting low light, or need higher shutter speeds in low light? Photographic Images on Brett Butler
JimG I feel thoroughly satisfied 12,255 posts Likes: 2 Joined Jun 2005 Location: Australia. More info | Sep 20, 2007 05:07 | #7 All the high ISO comparisons I've seen on the 'net so far look comparable. Certainly doesn't look like a huge jump up or anything. Gear Listhttp://www.codastudios.com.au
KeithR Goldmember 2,856 posts Likes: 1 Joined Aug 2006 Location: Blyth, Northumberland, NE England More info | Sep 20, 2007 05:10 | #8 Definitely not that straightforward, Jim - there are several thorough, well-conducted tests out there already which indicate that the 40D isn't that far behind the 5D.
sadowsk2 Goldmember 1,179 posts Joined Feb 2007 Location: Macomb, MI More info | KeithR - I'm sorry but the 40D won't touch the 5D in terms of noise... Its no better than the 30D... 1D Mk IV, 5D Gripped, 30D
Jon_Doh Senior Member More info | Sep 20, 2007 08:15 | #10 The advances made in 14 bit imaging and greater light gathering capabilities on the sensor are lost by reducing the size of the sensor. It's the same sensor in the XTi, just modified in its light gathering abilities. End result is a wash vis a vis the 30D in noise and IQ. Canon dropped the ball on this upgrade. The 10mp sensor in the Mark III does a much better job in the IQ department and in most areas, noise too. Why couldn't Canon have used this set up in the 40D? I use a Kodak Brownie
MaDProFF Goldmember 4,369 posts Likes: 2 Joined May 2007 Location: East Sussex, UK More info | Sep 20, 2007 08:19 | #11 Maybe it is to do with the fact the M3 cost 4 times as much. Photographic Images on Brett Butler
sadowsk2 Goldmember 1,179 posts Joined Feb 2007 Location: Macomb, MI More info | MadProFF - Low light conditions are where you're going to see noise creep up... Shots with siginificant lighting won't expose either systems true noise performance... Hence, I think my shots are very representative of how the noise performance is on the two cameras... For those who shoot in low light and truely need the high ISO (wedding halls, banquet halls, churches, etc) there is no difference... 1D Mk IV, 5D Gripped, 30D
MaDProFF Goldmember 4,369 posts Likes: 2 Joined May 2007 Location: East Sussex, UK More info | Sep 20, 2007 08:38 | #13 Well I am no expert but all your test shots for me seem to have the wrong WB, hence exposed wrong, thus more noise produced, as per my other post. Photographic Images on Brett Butler
sadowsk2 Goldmember 1,179 posts Joined Feb 2007 Location: Macomb, MI More info | MadProFF- The white balance was kept the same on the two cameras so as long as the settings were comparable its an apples to apples analysis. I can go back and adjust the white balance and I'll bet you they are both comparable. Second, in case you didn't realize or read properly, I indicated I applied no post processing to the images... As a wedding photographer, or photographer in general, you would realize adjusting the white balance after a shot is taken would be "post processing". My wedding photos have attracted quite alot of business, so thankfully I haven't been "shot" and hopefully if you ever shoot a wedding you won't either. 1D Mk IV, 5D Gripped, 30D
One of the largest factors in reducing noise is the amount of signal processing you do after the image is captured. The dual CPUs of the 1DMkIII allow significant more processing power. With only one processor in the 40D, you have to trade off the amount of processing you want to perform against your burst rate. Gear List
| Latest registered member was a spammer, and banned as such! 2724 guests, 143 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
