Thread started 21 Sep 2007 (Friday) 02:00
Extender for Canon EF 28-135mm f3.5-f/5.6 IS USM
rs666
Sep 21, 2007 02:00 |  #1
Having recently broken my 70-300mmm lenz I need a zoom but will have to save my pennies for the 70-200 L lenz I would like.
In the meantime can I get an extender for my Canon EF 28-135mm f3.5-f/5.6 IS USM that will so me through the next fews weeks?
30D....all the gear....and no idea!
00silvergt
"some dorky title"
Sep 21, 2007 02:06 |  #2
Which body are you using? The reason I ask is that you probably won't get AF even with the 1.4x Kenko with your lens with anything short of a 1D series, not to mention, Kenko advises against using it with focal lengths wider than 50mm. If you use it, I suggest only using it from teh 50-135 range. The Canon for sure won't work since it won't mount, it will bump into the rear element of your lens.
"Ne nuntium necare"
"We are building a fighting force of extraordinary magnitude. We forge our traditions from
the spirits of our ancestors. You have our gratitude."
https://photography-on-the.net …rgt/newlogo.jpg​%5B/IMG%5D
rs666
Sep 21, 2007 02:15 |  #3
Oops!
30D body
00silvergt
"some dorky title"
Sep 21, 2007 02:34 |  #4
Remember you will lose one stop with the 1.4x and 2 for the 2x. With the Kenko and my 70-300 IS @ f/5.6 which is actually f/8 I can only get the center focus point to work.
However, with the 70-200 f/4 which is f5.6 with the converter, I can get all points working. But I've read that since the AF is better, more sensitive with less light on the 1D series bodies, this shouldn't be a problem.
"Ne nuntium necare"
Canon ­ Bob
Sep 22, 2007 02:33 as a reply to  @ 00silvergt's post |  #5
I've never tried this before so I just popped outside with my wife's 350D, Kenko 1.4 and the 28-135.
I was amazed to get centre AF at max zoom up to f/11...no hunting, nothing.
Trying again in a lower light situation..under the trees...I lost the AF above f/5.6
It looks to me that it's workable in good light and high contrast despite what the spec's say....it amazed me!
Bob
1Dx2 (2), 5DSR, 1Ds3, 1D4, 5D2(590nm), 5D2(720nm) EF600 EF400 EF300-II EF300 EF200 EF200-II EF180L EF135L EF100 EF85-II EF50L TS-E17/4 TS-E24L-II TS-E45 TS-E90 MP-E65 EF70-200-II EF24-70/2.8-II EF16-35/4 EF8-15/4 EF11-24/4 Zeiss 15/2.8 21/2.8 25/2 28/2 35/1.4 35/2 50/2 85/1.4 100/2 135/2 T/C's L-SC & a WIFE!
1,594 views & 0 likes for this thread, 3 members have posted to it.
1685 guests, 172 members online
