There seems to be a misconception among some users about Custum Function III-2. I have seen it a few times here and I have been seeing alot in other forums.
So I thought I would post this to try and address the misconception. Also NOTE that I am not drawing any relationships between this and the Focus issues some are having with the camera.
C.Fn III-2 is used to set the AI tracking sensitivity and the set up for the function seems to be causing some confusion.
When you set this CF up you have Slow, Moderatley slow, 0 or normal, Moderatley fast and fast.
Some people believe that if they are shooting Fast moving subjects that this should be set to fast.
NOT TRUE.
This CF determines how fast the focus will change to a differant subject or focal point if something enters the view in front of or behind the subject.
So if you are tracking a Bird and have the CF set to fast the moment something passes in front of the bird or you move the focusing point of the subject the camera will refocus on the new object in the focal point.
If you want the camera to ignore things blocking you target while tracking it is better to set this CF to SLOW.
Fast would be used if you are wanting to use AI Servo to shoot mulitple subjects and what the camera to refocus everytime you move the Focal point to a new subject.
Here is a quite directly from the Canon Professional Network.
The heightened sensitivity of the EOS-1D Mark III AF system can, in some situations, cause the autofocus to appear erratic. In fact, it is not erratic at all, simply it is so sensitive that it will identify and re-focus on a new subject much faster than previous cameras – and crucially – much faster than you might expect.
Turning down this response rate to ‘Moderately Slow’ or ‘Slow’ will help when tracking subjects as the camera will not jump instantly to any new ‘subject’ or the background and should ensure a more familiar AF response. Note that this will not slow down the speed of the autofocus, only the speed at which the camera recognises a new subject. It’s like a buffer than provides you with more time and leeway to track a subject without the camera constantly finding new ones.
Hopefully this will help dispell the misconception, and help some people that may have set this Cf incorrectly and have been having problems.
