here's what i took today..
P mode @ F/22
What's going on... ?
Cr4zYH3aD Goldmember 1,024 posts Joined May 2007 Location: Canada More info | Sep 22, 2007 18:30 | #1 here's what i took today.. What's going on... ? ![]() Canon EOS 7D | Canon EF 100mm f/2.8L Macro IS USM
DDan Goldmember 1,725 posts Joined Nov 2006 Location: Oceanside, Calif. More info | Sep 22, 2007 18:45 | #2 Looks like lubricant goobers. I'm not sure though. I am making the assumption because it is a relatively new camera that has never been cleaned before. Right? You need a wet cleaning to get rid of them. My Gear
calicokat Cream of the Crop 14,720 posts Likes: 2 Joined Oct 2005 Location: Southern California More info | Sep 22, 2007 18:52 | #3 Looks fine to me, j/k "You are going to fall off a cliff trying to get a better shot someday"- My hopeful and loving wife
gjl711 Wait.. you can't unkill your own kill. 57,738 posts Likes: 4072 Joined Aug 2006 Location: Deep in the heart of Texas More info | Sep 22, 2007 19:03 | #4 You got dust.. It happens. Search around for cleaning sensors. However, yours is really not all that bad. I assume you used the "Auto Levels" function to highlight them. Not sure why, but call me JJ.
Sep 22, 2007 19:24 | #5 |
calicokat Cream of the Crop 14,720 posts Likes: 2 Joined Oct 2005 Location: Southern California More info | Sep 22, 2007 19:26 | #6 try the blower first, sometimes that works unless you are me "You are going to fall off a cliff trying to get a better shot someday"- My hopeful and loving wife
lol.. well. 35$ for a blower is expensive. But.. ill see what i can do. the xti's been off for 2 month until today. dont take it much..nothing to photography Canon EOS 7D | Canon EF 100mm f/2.8L Macro IS USM
DDan Goldmember 1,725 posts Joined Nov 2006 Location: Oceanside, Calif. More info | I'll bet $5 against a clean lens tissue that a blower will not clean your sensor. As I stated above, I believe it is excess lubricant that is thrown from the mechanicals on new cameras. My Gear
bigC Senior Member More info | Sep 22, 2007 20:42 | #9 If it's a new camera, I'd take it to Canon, and let the experts clean it (that's what I do). Flickr
GlennNK Goldmember 4,630 posts Likes: 3 Joined Oct 2006 Location: Victoria, BC More info | Sep 22, 2007 21:12 | #10 DDan wrote in post #3986579 I'll bet $5 against a clean lens tissue that a blower will not clean your sensor. As I stated above, I believe it is excess lubricant that is thrown from the mechanicals on new cameras. Ever oil the chain on a bicycle and get oil on your pants legs on the first ride? Same thing. You need the blower to remove any dust that might be there to minimize the risk of scratching your sensor during a wet cleaning though. If you are not using the camera much, it would be easier to get the sensor cleaned by Canon under warranty. Finally - someone that is saying the same thing I've been saying all along. When did voluptuous become voluminous?
edrader "I am not the final word" More info | Sep 22, 2007 22:22 | #11 Cr4zYH3aD wrote in post #3986544 lol.. well. 35$ for a blower is expensive. But.. ill see what i can do. the xti's been off for 2 month until today. dont take it much..nothing to photography http://instagram.com/edraderphotography/
Hermeto Cream of the Crop 6,674 posts Likes: 2 Joined Oct 2005 Location: Toronto, Canada More info | Sep 22, 2007 22:30 | #12 Permanent banWhat we see depends mainly on what we look for.
Sep 22, 2007 23:13 | #13 the local store ask too much then ! Canon EOS 7D | Canon EF 100mm f/2.8L Macro IS USM
BillBoehme Enjoy being spanked More info | Sep 22, 2007 23:44 | #14 Glenn NK wrote in post #3986976 Finally - someone that is saying the same thing I've been saying all along. Dust be damned - some of this stuff sticks like you-know-what-to-a-blanket. Of course the moving parts (mirror, shutter mechanisms) are lubricated. How long will a car engine run after you pull the oil pan drain plug? I agree about the blower idea though - get as much loose stuff off as you can. Unless your camera has an oil sump akin to an internal combustion engine, I would say that oil is highly unlikely. This is just ordinary dust that accumulates on all things photographic related. What minuscule amount of lubricant is used on moving parts in the camera isn't going to be slinging off onto all of the internal surfaces. There are not gobs of grease on all internal moving parts, but just just microscopically thin layers on a few moving parts. Besides, if it were oil, shouldn't you expect identifiable pattern characteristics if the contamination were oil from moving parts since this would be related to repetitive motion from parts that are in a fixed mechanical relationship to the sensor? Most of the internal mechanism is not lubricated at all -- remember that oil acts as a viscous damper and that is not something that would be desirable when you need very high speed shutter and mirror accelerations. Atmospheric haze in images? Click for Tutorial to Reduce Atmospheric Haze with Photoshop.
DDan Goldmember 1,725 posts Joined Nov 2006 Location: Oceanside, Calif. More info | Sep 23, 2007 00:41 | #15 bill boehme wrote in post #3987856 Unless your camera has an oil sump akin to an internal combustion engine, I would say that oil is highly unlikely. This is just ordinary dust that accumulates on all things photographic related. What minuscule amount of lubricant is used on moving parts in the camera isn't going to be slinging off onto all of the internal surfaces. There are not gobs of grease on all internal moving parts, but just just microscopically thin layers on a few moving parts. On what do you base this opinion? I am open to ideas that are counter to what I have observed. My Gear
| Latest registered member was a spammer, and banned as such! 2728 guests, 159 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
