Thread started 22 Sep 2007 (Saturday) 20:36
how can i achieve this kind of image? b/w w/t color
implayaz9
Sep 22, 2007 20:36 |  #1
i wanna know how to get come colors acents in a black white pic. how is it achieved?
here is an example:
http://i75.photobucket​.com …/implayaz9/Valv​eCover.jpg (external link)
20D | 28-135 IS | Sigma 10-20 | 50mm | 17-40 L
jra
Sep 22, 2007 21:48 |  #2
Very simple in PS....Simple make a B/W layer with a mask. "Paint" away the mask on the areas you would like to have in color.
EOS_JD
Sep 22, 2007 21:55 |  #3
Selective Color. There's many tutorials on the web. Do you have photoshop?
First create a duplicate of the background layer (Control J)
Second, select Layer 1 and create an adjustment layer (if you have CS3 a B&W one - if CS2 a Channel Mixer one) - see image "Selective1" (on my CS3). (top image) To create an adjustment layer, select the half black/half white circle in the layers pallet. then select your required adjustment layer.
Now select D to set the foreground/background to default and press X until black is foreground. Now click on the white mask and paint over the area you want in colour.
Note that the mask is now showing black where you painted and is showing the colour from the layer beneath (in the background layer). This is like laying a white sheet over your image and cutting out holes (painting black) to show the layer below.
See "Selective2" image attached (bottom image)
In the above image I made an error. The flowers to the right are in colour and I want them B&W. Easy. Just press X to switch from black to white as foreground colour and select the white mask again. Now just paint white on the mask. Use a small brush and zoom right into the areas you are working on so you get it right.
You will end up with the image on the next post.
All My Gear
5D MkIII & 5D MKII + Grips | 24-70 f2.8L IS | 24-105 f4L IS | 70-200 f2.8L IS MkII | 50 f/1.4 | 85 f1.8 | 100 f2.8 | 1.4x MkII | Tamron 17-35 f2.8-4
EOS_JD
Sep 22, 2007 21:57 |  #4
And you'll end up with this
All My Gear
EOS_JD
Sep 22, 2007 22:09 |  #5
This is a quick way and very easy to amend errors. Many will advise deleting the top layer but this is bad if you make a mistake and need to go back in the history as you can lose many minutes of work.
Adjustment layers and masks in general are very useful.
An adjustment layer is editable too. The above was created with the default B&W options. I clicked back into it by double clicking the black/white circle next to my white layer and amended the B&W defaults to make this.
I should add that I only chose this image to show the larger black areas on the mask. This is not how I would normally do this technique. The image you showed is very easy to do following this method.
Hope it helps.
JD
All My Gear
implayaz9
Sep 23, 2007 00:06 |  #6
i have photoshop7. i made 2 layers but after that i was totally lost.. sorry not pro at photshop
EOS_JD
Sep 23, 2007 01:17 |  #7
implayaz9 wrote in post #3987938 (external link)
Look on the layers pallet. At the bottom is there a black/white circle? That will add an adjustment layer of your choice. With Ps 7, try channel mixer.
When the Channel Mixer comes up, select Monochrome and then adjust your image to suit. The channels can be mixed to create different B&W images but the numbers should add up to around 100 (usually a little higher). Mine add up to around 110.
Once you click ok, click on the white mask (on the adjustment layer) and follow my instructions regards painting black (use the brush tool - press B on the keyboard).
All My Gear
implayaz9
Sep 23, 2007 01:32 |  #8
i figured out the channel mixes but now cant seem to figure how to do the mask or kind dont get how to do the maks part
EOS_JD
Sep 23, 2007 02:04 |  #9
If you have created the adjustment layer, there should be a white layer in your layers pallet. Just click on that white layer to select it and paint black on it over the area you want to show in colour.
Print your screen and save it as 800 pixels on the longest edge then post it here and I'll have a look.
All My Gear
1,853 views & 0 likes for this thread, 3 members have posted to it.
2076 guests, 165 members online
