ejwebb wrote:
Good point - thought about that after I posted. I'll have to give it a try. I had seen others say they would not put cheap glass in front of expensive glass but if there is no discernable quality impact on the images the expensive filters seem to be a waste of money - at least for me - but I do want the best quality I can get from what I have. Granted, if I spent $1,500 for a lens I would probably put a $100 filter on it, too.
Thanks for your feedback.
The problem is that you can't tell a good filter from another by just looking at it.
As I wrote a couple of days ago I had a cheap filter on a 300mm f4.5 Nikkor lens. I'd use this lens along with a Nikkor 180mm ED lens and the difference in contrast was obvious just glancing at the negatives. I just assumed that this was the difference between the ED glass and the regular stuff.
Anyway I removed the filter one day and then the new negs were identical between the two lenses. There was a Nikon L37C filter, Nikon speak for a UV on the 180 the whole time. So I broke down and bought an L37C for the 300 and all was well. But looking at the Brank X filter that coused all the problems revealed no obvious cause. It looked fine and wasn't nearly as chewed as some of my Nikon filters were.
My suggestion is to get a really good filter, and Canon filters are really good, and not try to save a couple of bucks with the Toko filters of the world.
"There's never time to do it right. But there's always time to do it over."
Canon 5D, 50D; 16-35 f2.8L, 24-105 f4L IS, 50 f1.4, 100 f2.8 Macro, 70-200 f2.8L, 300mm f2.8L IS.
