Never mind... you got it... i was preparing this post before you posted that you got it... my bad...
You shouldn't have that big of a problem...
What i did was:
1) install EOS-1D Mark II WIA drivers since my windows version didn't know the camera...
2) run the canon software (already had it installed from my Canon 20D)
3) after running the EOS Viewer Utility, started scratching my head trying to figure out why didn't i have all the options available...
4) searched the net, and here in this forum found out that i needed a frewire cable
5) got a firewire cable, and all worked well
#1 - this is what i got with a USB cable connected
| HTTP response: NOT FOUND | MIME changed to 'image/gif' |
#2 - this is what i get with the firewire cable connected
| Byte size: ZERO | Content warning: NOT AN IMAGE |
#3 - this is the option that shows up after pressing the camera settings option, and what you're searching for
#4 - and this is what shows up on the device manager window whem i have the camera connected via firewire
P.S.: i'm using a old version of the software, it's version 1.2.1.14. I never updated it because this one works and i only use it to have the remote control option available, other wise i use lightroom and photoshop to edit my photos.
Hope this helps...
