Thread started 22 Jul 2004 (Thursday) 22:46
lenses for infrared
msvadi
Joined Jul 2003
Jul 22, 2004 22:46 |  #1
I found this list on dpreview forums: http://forums.dpreview​.com …orum=1019&messa​ge=5429735 (external link)
I thought that some people here might be interested.
Good
Canon EF 17-40mm L f/?
Canon EF 24-70mm f/2.8 L
Canon EF 28-135mm/3.5-5.6 IS
Canon EF 28mm f/2.8
Canon EF 35mm f/2
Canon EF 50mm f/1.8 MKI
Canon EF 50mm f/1.8 MKII
Canon EF 70-200mm f/4L
Canon EF 75-300mm/4.0-5.6 IS
Canon EF 135mm f/2L
Canon EF 100-400mm4.0-5.6 IS L
Canon EF 100mm f/2.8 macro
Bad
Canon EF 16-35mm f2.8 L
Canon EF 20mm f/2.8
Canon EF 24-85mm f/?
Canon EF 28-70mm f/2.8L
Canon EF 28-105mm f/?
Canon EF 35-80/4.0-5.6
Canon EF 50mm/f1.4
Canon EF 50mm/f2.5 Macro
Canon EF 70-200mm f/2.8L IS
Canon EF 85mm f/1.8
Tamron 70-300mm f3.x-xxx Macro
17-40 is in the good category, but some people noticed the hot spot. In addition to the list, there are reports that Tamron 28-75 XR DI f/2.8 also suffers from hot spot problem, so it goes into the bad category. I wonder if all lenses designed for digital get some IR blocking coating, which seems to cause the hot spot problem.
polloloco81
Joined Jun 2003
Jul 22, 2004 23:08 |  #2
That's just great :( The only lense that I own that's on the good list is the 50mm, and it's a 52mm thread. And I have a 58mm Hoya R72 filter. Woe be me! Such divine irony!
POLLOLOCO81
http://www.manhadesign​.com/indexx.php (external link)
msvadi
Joined Jul 2003
Jul 22, 2004 23:21 |  #3
you can get a step down ring, so it's not a big problem. personally, I think it's better to get a Cokin set-up. One can use same filters on all lenses. Cokin now has an IR filter 007. It's similar to Hoya R72.
by the way, this list may be not very accurate. I mention that some people had problems with 17-40. I also saw reports that 28-135 had a hot spot.
anyway, I think that cheaper lenses are better for IR - less chances that some IR coating was applied to it. Now, I'm actually seriously thinking about that Russian fisheye lens that was discussed some time ago. I'm sure it should be okay for IR.
Conk
Joined Jul 2002
Jul 22, 2004 23:44 |  #4
Looking at the list I have to wonder where IS comes to play with IR photography. Is it that these just happen to be the lenses tested and used. Wouldn't a 75-300mm lens be just as good as the IS lens for IR purposes?
Cloverdale Photography (external link)
Photos (external link)
More Photos (external link)
msvadi
Joined Jul 2003
Jul 23, 2004 09:45 |  #5
I understand that IS and non-IS versions have similar optics, so, the non-IS should be good too. The lens goes into the Good category if it does not show "hot spot" in IR shots.
There is another important factor - IR index. I wonder what Canon lenses have it. The only lens with the IR index that I know of is 135mm f/2.8 Soft Focus.
Calis
Joined Jan 2004
Jul 23, 2004 15:42 |  #6
You can ad the kit EF-S 18-55 to the 'bad' list.
That being said a bit of photoshopping gets rid of the hot spot fairly easily. See my recent post
http://www.photography​-on-the.net/forum/showthre​ad.php?t=38146
The first pic was with the kit lens and it worked out ok with a bit of post processing.
Phil
www.pbase.com/calis (external link)
Aschlaman@comcast.net
Aug 19, 2005 12:48 |  #7
I was wondering if anyone had experience with the 17-85mm IS lens and the R72 Infra red filter. I bought this filter for this lens but my results are not that great. Perhaps it's just that the lens is not suitable. Anyway any enlightenment will be appreciated.
Thanks in advance
Art Schlaman
Canon 20D, 35mm f 1.4L, 50mm F1.4. 85mm F1.8,85mm f1.2L, 135mm f2.0L 18-85mm IS, 17-40MM f4L,
300mm IS F4L, 70-200MM f2.8L IS, 100-400mm L, 75-300mm IS,135mm soft focus
Tamron 28mm-75mm f 2.8, Tamron 180mm f2.8 macro, 580 EX flash, EOS3
Canon G6, EOS3
Hasselblad Xpan w/ 30mm and 45mm
Contax Aria, 21mm, 25mm, 28mm, 35mm, 50mm, 85mm
Fuji GA645i, GA670III
Epson RD-1 with Zeiss ZM 35mm f 2 and lots of Leica's
Epson P2000 storage device
leonsteber
1 post
Sep 08, 2007 13:51 |  #8
Hi everyone,
I've looked everywhere for info on the following but it doesn't seem to turn up on any of these good/not good for IR lists:
EF 50mm f/1.2L USM
EF 70-200mm f/2.8L USM
Does anyone have any experience with these? Just want to know if they experience hot spots before I invest in a IR filter...
Cheers
Leon
http://www.geocities.c​om/leon_maurice_and_ty​rone (external link)
argyle
Sep 09, 2007 13:15 as a reply to  @ leonsteber's post |  #9
Is this list for lenses that are good/not good for use on cameras that have been converted for IR, or for use with an IR filter? I'm looking to get into IR, and I suspect that there would be a difference. With a camera that's been converted, the lens will see the actual light and the conversion is done on the sensor. With an IR filter in front of the lens, the lens is seeing the IR spectrum. Is this correct? If so, what the list apply to? I've seen on the lifepixel site that their standard conversion is calibrated to the 50/1.8 lens (as far as Canon equipment).
14,207 views & 0 likes for this thread
lenses for infrared
Latest registered member is m.nobles
787 guests, 158 members online
