Thread started 24 Sep 2007 (Monday) 10:28
Help! My BG-E4 is stuck!
scot079
Sep 24, 2007 10:28 |  #1
I cranked it down so tight that the inner sprocket broke...do I need to pry it off and buy another one?
- Tim
www.timadkinsphoto.com (external link)
GEARandFEEDBACK
cctsm
Sep 24, 2007 10:31 |  #2
I think you should rather send it to Canon. I doubt prying it off would be entirely too healthy for your camera.
Why the heck did you tighten it that much anyway?
Canon: EOS 50D, EOS 400D, EF 300mm f/4L IS USM, EF 50mm f/1.8 II, EF-S 18-55mm f/3.5-5.6 II, EF 1.4X Extender, Speedlite 430EX
Sigma: 10-20mm f/4-5.6, 55-200mm f/4-5.6 | Tamron: 17-50mm f/2.8 | Manfrotto: 055 XPROB tripod, 680B monopod, 804RC2 and 486RC2 heads
Kenko extension tubes, Sandisk Extreme III 2GB + 8 GB & Ultra II 4GB
scot079
Sep 24, 2007 10:34 |  #3
I can take it apart without breaking the camera, I've done it on my 30D (embarassed smiley face)
I just got tired of it coming loose
- Tim
GEARandFEEDBACK
Bukka
Sep 24, 2007 11:14 |  #4
Ohhh I had that happen....
I used a flathead screwdriver in the teeth, and used a little bit of pressure. came right undone. Now i'm sure to never tighten it that tight ever again.
Switched to the "dark side" but I like these boards.
Digital: Nikon D200
Lenses: Nikkor 50 1.8D, Nikkor-P 55 macro 3.5, Nikkor 35 1.8G Nikkor 85 1.8.
Film: Canonet QL17 G-III, Bell&Howel/Canon Dial 35,
scot079
Sep 24, 2007 11:16 |  #5
LOL, so how did you get the grip off the camera?
- Tim
GEARandFEEDBACK
Bukka
Sep 24, 2007 11:18 |  #6
OHHHH NEVER MIND!
sorry *blush* my sprocket didn't break... I did over tighten though
Digital: Nikon D200
S ­ Taylor
Sep 24, 2007 11:19 as a reply to  @ scot079's post |  #7
I had the crappy grip for the 20D get stuck last year. I ended up having to use a hacksaw. I vowed then to never own another Canon grip! :evil:
Good luck.
Scott
Couple of DSLRs, number of lenses and other stuff... plenty short on talent.
https://photography-on-the.net …p?p=2200252&pos​tcount=281
PsyFactor
Sep 24, 2007 13:11 |  #8
When that happens try to following:
1) put the camera + grip on your lap (or on a low table)
2) press down the camera with one hand and unscrew the grip using the other hand.
That how I was able to remove the grip from my camera when it got stuck.
scot079
Sep 24, 2007 13:23 |  #9
Roger that, will try and report back. Danke Shoen Herr PsyFactor
- Tim
GEARandFEEDBACK
1,405 views & 0 likes for this thread, 5 members have posted to it.
2840 guests, 150 members online
