What is the best metering mode when dealing with bright colors typically found at weddings such as bridesmaids' dresses and white wedding gowns? Evaluative, partial, spot, or center-weighted average metering? Thanks.
Tabby Member 38 posts Joined Sep 2007 More info | Sep 24, 2007 15:53 | #1 What is the best metering mode when dealing with bright colors typically found at weddings such as bridesmaids' dresses and white wedding gowns? Evaluative, partial, spot, or center-weighted average metering? Thanks.
RickRosen Member 240 posts Joined Apr 2005 Location: So. CA More info | Sep 24, 2007 15:58 | #2 With digital is is always a good idea to bias your reading for the highlights. I meter off the brightest highlights on the bride's white dress then open up the exposure by 2 stops. I then take a test exposure and view the histogram and adjust the exposure if needed. Then I shoot on manual. Best regards,
Nan08 Member 70 posts Joined Jan 2007 Location: Ca More info | Sep 24, 2007 16:01 | #3 Yup, meter the highlights, then adjust accordingly. You might want to have a gray card if needed. Ronan
| Latest registered member was a spammer, and banned as such! 2203 guests, 138 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
