rogertb wrote in post #4002820
Yep i used a tripod and the self timer ... manual focus. The iso wont affect the softness though will it and please, forgive my ignorance, what's the "... lens calibration..." ?
Here's a shot I just took in daylight I increased ISO to 400 plus a little exposure compensation and manually focussed (I thought the auto focus version was a smidgen softer) ... I guess this about as good as I'm going to get with such a cheap lens.
Thanks for your time Roger
ISO won't directly affect image sharpness, but if you raise the ISO, you can increase the shutter speed (or decrease the aperture) correspondingly without affecting total exposure: 1/320 s @ f/5.6 @ ISO 100 = 1/640 s @ f/5.6 @ ISO 200 = 1/640 s @ f/8 @ ISO 400, etc., and a faster shutter speed can mitigate camera or subject movement problems.
Lens calibration is where the focusing mechanism and/or optical alignment of the lens elements is checked, and corrected if necessary.
That image of the car does look soft, so something is not right. The lens will perform better optically stopped down a little, but the EXIF for this shows f/45! If that is real, then you could well be into diffraction territory - another problem area.
Try f/11, with a shutter speed of no less than 1/500s if carefully hand held, or maybe slower with a good tripod. Adjust ISO (and maybe aperture +/- a stop, that is, from f/8 to f/16) in order to get correct exposure.
Don't write off the lens quite yet - you may just need to find its "happy place"
Additional thoughts:
Do you have other lenses? Are they sharp? I'm just wondering if it is a body problem. Another issue could be that if you are manually focusing, and the viewfinder dioptric adjustment is off, it could be difficult to set correctly. That's the little adjustment wheel on the viewfinder housing used to compensate for your own eyesight. Adjust it so that the camera data displayed in the viewfinder is as sharp as possible.
