Thread started 25 Sep 2007 (Tuesday) 21:01
what lens to what camera and why?
MrsOpie
Sep 25, 2007 21:01 |  #1
i just purchased a Canon 20D (the baby) to go with my Canon 5D (the big mother). I also have a 24-70/2.8 and a 70-200/2.8. What lens should I put on what body and why? I plan on using both cameras during the ceremony and then just using 1 camera for formals/reception. I've never shot with a 2 camera combo so I would like some advice. :)
-OpieFoto
Salt Lake City Utah Wedding Photographer (external link)
Modern, Bold, Raw Emotion
Livinthalife
Sep 25, 2007 21:03 |  #2
24-70 on the 5D for wide shots, and the tele on the 20D for the crop factor.
That's what I would do. congrats on the "new" camera!
-Andy-
notapro
Sep 25, 2007 21:06 |  #3
I'm interested in hearing responses to this too. don't mind me while I subscribe...
Amanda
Ontario Wedding Photographer  (external link)| My Blog (external link)
tim
Light Bringer
Sep 25, 2007 21:14 |  #4
Livinthalife wrote in post #4007588 (external link)
I agree, for those reasons.
cccp145
Sep 25, 2007 21:20 |  #5
same
MrsOpie
Sep 25, 2007 21:22 as a reply to  @ cccp145's post |  #6
the 70-200 is a heavy lens can the 20D handle the weight of the lens?
-OpieFoto
JaertX
Sep 25, 2007 21:26 |  #7
MrsOpie wrote in post #4007708 (external link)
yes...that's the combo I used for quite a while.
Jason - I use Canon and stuff
tim
Light Bringer
Sep 25, 2007 21:39 |  #8
Yes, no problem. With big lenses you always support the lens and let the camera hang off the back.
MrsOpie
Sep 25, 2007 22:09 as a reply to  @ tim's post |  #9
I plan on having both cameras around my neck so one of them will be just hanging there pointing at the ground while I'm shooting with the other.
-OpieFoto
tim
Light Bringer
Sep 25, 2007 22:11 |  #10
I find that gets uncomfortable, I leave the camera i'm not using on the ground. The 20D will probably be fine with the 70-200 F2.8 hanging off it, but I wouldn't do it regularly to my own camera/lens.
MrsOpie
Sep 25, 2007 22:20 |  #11
tim wrote in post #4008020 (external link)
So tim what your saying is have the 5D and 24-70 combo on my neck and the 20D and 70-200 combo on the ground and then pick it up every so often to take a close up shot? I tend to move around a lot to get different shots during the ceremony. I'm open to ideas. How do you do it?
-OpieFoto
tim
Light Bringer
Sep 25, 2007 22:33 |  #12
MrsOpie wrote in post #4008071 (external link)
My 70-200 gets left in the aisle during the ceremony, and carried if I want it to come with me.
Tish
Sep 25, 2007 23:05 |  #13
This is typically what I do--both 20Ds are on me, but the 17-55 is around my neck & the 70-200 on the ground/floor if I'm stuck in one place for any length of time. If I'm truly on the run the whole ceremony, I have them both physically on me, with the 70-200 on my right shoulder. The strap is long enough that I can pull into position to use, then drop it back out of my way to use the shorter strapped one around my neck.
The 70-200 and the 20D do just fine. I do prefer to use a grip & handstrap with that combo though, it's a LOT more comfortable if you're doing any significant shooting.
I've finally started a blog. Really. (external link)
cdifoto
Don't get pissy with me
Sep 25, 2007 23:12 |  #14
Yep make your long lens longer and your wide lens wider. No-brainer to me. Same reason I go with the 24-70 on the 1D and 70-200 on the 10D. I also hang the 10D/70-200 combo around my neck all the time and let it hang. No biggy, no concerns.
jessiper
EEK! I don't want a title anymore!
Sep 25, 2007 23:19 |  #15
That's exactly why I put the 24-105 on my 5D and the 70-200 on my 30D. 24mm isn't wide enough on the 30D.
Congrats, as well!
*Gear: 5D Mark II, 2 5D's, 30D, 85mm 1.8, 50mm 1.4, 24mmL 1.4, 45mm TS-E, 16-35mmL 2.8 II, 70-200L 2.8 IS, 100mm 2.8 macro, 15mm 2.8 fisheye, 580EXII, 580EX, 430EX, AB 800, AB Ring flash, lots of PW's, stands, umbrellas, etc.
Oregon wedding photographer (external link)
1,400 views & 0 likes for this thread, 12 members have posted to it.
2291 guests, 129 members online
