Hi All
Only just had the chance to get the 40D out of the box 2 days after getting it.
Inserted battery switched on and nothing, zilch, zero oh b%&***er I thought better get it packed up to be taken back to the shop.
OK quick check through as whther there is an incidently cause. Cut a not too long story short I took the battery out and reinserted but still no go, hmmm! try to just push down on the battery aginst its end stop and gave it a little wobble (or what passes for a wobble in the space. Lo and behold it starts it when when switched on.
About hundred shots of 'rubbish' just to quickly work through some of the settings and all seems well.
Not sure what could have been wrong but I do take care when inserting the battery and CF card and yes the battery was in and locked down the first time
so I surmise it was just an oddity which most folk may never have seen because they maybe just push the battery in that little bit harder.
Well, so far so good but will have to ensure that if it happens again it happens soon and repeatably in case it needs to go back.
