Thread started 27 Sep 2007 (Thursday) 03:41
40D High ISO Noise Example (With Crops)
agent.media
Sep 27, 2007 03:41 |  #1
I have been reading these forums for a while, and I have noticed alot of 40D noise examples around purporting to be in "low light" at High ISO.
Unfortunately I don't believe you are testing the noise ability (or inability) of a cameras sensor if you are shooting faster than 1/100 s. So here are a couple of examples. All of these were processed with Lightroom, and nothing more.
The following two examples were shot with the Canon 50mm 1.4, beware it goes down for a bit.
1/100 s 1.4 ISO 1600
Crop 1
Crop 2
1/50 s 1.6 ISO 3200
Crop 1
Crop 2
Gope this gives 40D hopefulls a good indication!
As for me, I LOVE IT! Many times better than ISO 3200 on my old Konica Minolta 5D
Alex
www.flickr.com/photos/​lamul (external link)
40D, 17-55mm 2.8, 50mm 1.4, 430EX, lots of Strobist gear.
MaDProFF
Sep 27, 2007 03:47 |  #2
it is a shame you did not shoot the same subject at different shutter speeds to prove the point you are trying to make.
But I agree if you get the settings right on the 40D i think the noise is slightly better than 30D, but if you get it slightly wrong it is worse than the 30D slightly wrong.
Photographic Images on Brett Butler (external link) px500 (external link) & Flickr (external link) Some Canon Bodies , few blackish lenses, A dam heavy black one, couple dirty white ones, a 3 legged walking stick, a mono walking stick, and a bag full of rubbish :oops:
And Still Learning all walks of life, & most of all Photography.
agent.media
Sep 27, 2007 03:53 |  #3
I guess I wasn't trying to prove the point that higher shutter speeds give more noise. I was under the impression that it was common knowledge.
But that is a good idea! I'll do it sometime shortly.
Alex
Keith ­ R
Sep 27, 2007 06:00 |  #4
Thanks for this, Agent.
Prof, a higher shutter speed simply means (all other things being equal) that there's more light available to the camera - a sub 1/100 shutter speed implies proper low light shooting.
radiohead
Sep 27, 2007 06:06 |  #5
Indeed it does - an ISO3200 shot with a shutter speed of 1/1000s make me ask why you'd use 3200 in that situation? More light being available means choosing a more appropriate ISO setting. It also means less shadows are likely and that's where you're more likely to see real noise.
I saw a D3 shot taken at ISO6400 with a shutter speed of 1/2500s - it proves little.
Guy Collier Photography - Documentary Wedding Photographer (external link)
"All the technique in the world doesn’t compensate for the inability to notice." - Elliott Erwitt
"It's no good saying "hold it" to a moment in real life." - Lord Snowdon
My kit
John_B
Gallery: 178 photos
Sep 27, 2007 06:15 |  #6
agent.media,
You didn't look to hard then. ???
I had posted a test comparing the 40D to the 5D with long exposures from 1 second all the way to 1/8000th a second, high ISO 1600 with large aperture test here (external link)
However I do agree with you, as I love my 40D too :)
click to see (external link)
mcmadkat
Sep 27, 2007 06:33 |  #7
To me it looks like you still had the Lightroom noise reduction turned on, the distinctive grain kinda gives it away.
30D 17-40L 580EXII
https://photography-on-the.net/forum/showthre​ad.php?t=386249
agent.media
Sep 27, 2007 07:17 |  #8
You might be right, As I never checked it.
And to boot, I had the internal camera noise reduction on.
Alex
canonpink
Sep 27, 2007 07:22 |  #9
That noise appears manageable.
CP
No signature, but a bunch of gear.
Kennymc
Joined May 2003
Sep 27, 2007 07:28 as a reply to  @ canonpink's post |  #10
A quick run through Noisware and it will be very manageable...
www.kennymc.com (external link)
Equipment http://kennymc.com/Inf​ormation/equipment.htm​l (external link)
http://www.kennymc.com​/equipment.htm (external link)
TMR ­ Design
Joined Feb 2006
Sep 27, 2007 07:28 as a reply to  @ canonpink's post |  #11
As a related comment.....
Create a preset in Lightroom with no sharpening or noise reduction and make that the default preset on Import. Then you don't have to think about those parameters and you always start from 0.
Robert
agent.media
Sep 27, 2007 07:41 |  #12
Awesome suggestion! Thanks!:)
Alex
convergent
Gallery: 34 photos
Sep 27, 2007 09:42 |  #13
Keith R wrote in post #4017457 (external link)
So then what would the sports shooter do? I routinely shoot at very high ISO and shutter speeds much higher than 1/100 to stop action. It seems to me that you pick the aperture and shutter speed you need for the effect you want, and then the availability of clean higher ISOs allows you to not have to make as many sacrifices.
Mike
R6 II - RF 100-500L f/4.5-7.1 IS - EF 17-40L f/4 - 24-70L f/2.8 II - 70-200L f/2.8 IS II -
135L f/2 - 100 f/2.8 Macro - Siggy 15 f/2.8 Fisheye - RF TC1.4 - EF TC1.4 II - TC2 III - (2) 600EX-RT - ST-E3-RT
pilot1962
Joined Feb 2006
Sep 27, 2007 11:44 |  #14
Kennymc wrote in post #4017756 (external link)
Agree, since I found Noisware - I'm back in love again with my 20D...
And 40D frames after Noisware - couldn't be better!
Rumjungle
Sep 27, 2007 12:26 |  #15
mcmadkat wrote in post #4017561 (external link)
Looks like it to me too. If you've never played with the default settings, LR should be set to Luminance 0/Color 25 (I think).
Are you all saying that higher shutter speed produces more noise?
Gear
3,181 views & 0 likes for this thread, 13 members have posted to it.
2809 guests, 164 members online
