Do you guys have any tips on how to sequence your image numbers when using two cameras? I can see I'm going to run into problems due to same image numbers
Crypto Goldmember 2,648 posts Likes: 9 Joined Aug 2005 Location: Northern Va More info | Sep 28, 2007 14:27 | #1 Do you guys have any tips on how to sequence your image numbers when using two cameras? I can see I'm going to run into problems due to same image numbers TCProimages
DougPardee Senior Member 838 posts Joined Feb 2007 Location: Southern California, USA More info | Sep 28, 2007 14:55 | #2 The straightforward solution is to use a downloader program to rename the files when you pull them off the cards. "Downloader Pro" from Breeze is frequently mentioned. Myself, I use my DAM software (idImager Pro).
FlyingPhotog Cream of the "Prop" 57,560 posts Likes: 178 Joined May 2007 Location: Probably Chasing Aircraft More info | Sep 28, 2007 15:24 | #3 Crypto wrote in post #4026717 Do you guys have any tips on how to sequence your image numbers when using two cameras? I can see I'm going to run into problems due to same image numbers I use Lightroom and it easily allows me to rename the files. Jay
thanks for the info guys TCProimages
Photodawg1 Goldmember 3,059 posts Likes: 1 Joined Jan 2006 Location: Maryland More info | Sep 28, 2007 18:56 | #5 Good info! I will be needing that too. ______________
milleker Goldmember 1,851 posts Joined Feb 2006 Location: Baltimore, Maryland More info | Sep 28, 2007 22:34 | #6 I just ran into a problem with my two 20D bodies. Whats the odds, 1 on 10,000 that my two bodies would reach the same number on the same day? Would have lost about 150 images if I hadn't had a backup. ---John Milleker Jr.--
milleker Goldmember 1,851 posts Joined Feb 2006 Location: Baltimore, Maryland More info | Sep 28, 2007 22:36 | #7 Linda and Tom, check out my signature - having a Maryland POTN meet on Oct 7th! ---John Milleker Jr.--
MrWills Senior Member 684 posts Joined Aug 2006 Location: Seattle, WA More info | Sep 28, 2007 23:09 | #9 I down load them into different folders then name them all a,b,c,d ext for the order I want then put them all in one folder then rename them all at once one last time. Shawn
Mark_Cohran Cream of the Crop More info | Sep 28, 2007 23:23 | #10 I've been using multiple cameras for several years now. As long as the files are downloaded into different folders and the folders are properly named, there's should be issues with duplicate file names. Like others, I rename my files to conform to my own filing methodology, but even if you didn't rename the files, a good library file structure should prevent issues. Mark
milleker Goldmember 1,851 posts Joined Feb 2006 Location: Baltimore, Maryland More info | Sep 28, 2007 23:36 | #11 I have implemented Peter Krough's (Digital Asset Management book) naming scheme and directory structure. I could make a directory for each camera inside my main structure but I really enjoy having everything in one folder and then separated into DVD sized folders. ---John Milleker Jr.--
basroil Cream of the Crop 8,015 posts Likes: 2 Joined Mar 2006 Location: STL/Clayton, MO| NJ More info | Sep 29, 2007 01:51 | #12 with anything but 1d series, i would suggest batch renaming by date, but make sure that you keep the files in separate folders or else there is a chance you'll overwrite files (assuming the numbering is close enough to overlap). on 1d, just set the custom filename to 1d1 and 1d2 (or similar) and then rename... or just get lightroom and categorize your catalog by shoot time and you're fine 95% of the time (how many times will you shoot both cameras at the same time?) I don't hate macs or OSX, I hate people and statements that portray them as better than anything else. Macs are A solution, not THE solution. Get a good desktop i7 with Windows 7 and come tell me that sucks for photo or video editing.
Photodawg1 Goldmember 3,059 posts Likes: 1 Joined Jan 2006 Location: Maryland More info | Sep 29, 2007 02:03 | #13 milleker wrote in post #4029324 Linda and Tom, check out my signature - having a Maryland POTN meet on Oct 7th! John, ______________
| Latest registered member was a spammer, and banned as such! 2921 guests, 169 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
