Thread started 29 Sep 2007 (Saturday) 10:08
Custom White Balance
mnez17
Sep 29, 2007 10:08 |  #1
Hi,
I am shooting pictures next week at my nephew's wedding. Let me start out saying they have hired a professional, I am just taking pictures as you normally do at any occassion. I've mainly shoot football and baseball during the day and not too familiar with taking pictures in-doors. When setting the custom white balance (and if you plan on using the flash indoors) do you need to take the intitial picture with the flash on or off ?
Canon 1D Mark III|Canon 40D| Canon 350D| Opteka Battery Grip| 430EX| EF 85mm f/1.8 USM| EF 70-200mm 2.8L USM|EF 300mm IS 2.8L|EFS 17-55mm IS USM 2.8 |Kenko 1.4X
A.L. Sports (external link)
MaxPreps Profile (external link)/Sports Shooter (external link)
DWFoto
Sep 29, 2007 10:38 |  #2
The flash should be on. But it gets to be complicated depending on how far away your subject is, how strong your flash is, what the other sources of light are, what ISO you use, if you'll be taking pictures at different distances and in different locations inside, etc.
Shooting in RAW would allow you to easily adjust the white balance in post processing and you wouldn't have to worry as much about all the variation (if such things worry you that much :)).
Edit: just noticed your 85mm f/1.8 lens in your gear list. With that lens you probably could bump ISO up and shoot without flash at all, making white balance a bit simpler.
cdifoto
Don't get pissy with me
Sep 29, 2007 10:41 |  #3
I only do custom white balance when I shoot ambient light only....and that's rare.
lukasgunar
Sep 29, 2007 15:03 as a reply to  @ cdifoto's post |  #4
You should definitely shoot in RAW so you don't need to be worried about this during wedding and leave WB on Auto and later to tweak WB in Camera RAW.
I would consider buying of whibal card (the smallest one is not that expensive) and it's always good to have it (it will streamline your post processing).
Good luck.
lukas
Sony A7RIII
Samyang 45 f/1.8, paired with Sigma converter: Canon 16-35 f/4L IS, Canon 70-200mm f/2.8L IS II, Canon Speedlite 580EXII
stuff I owned for years until I moved to Sony world
Canon EOS 5D MkIV,Canon 17-40 f/4L, Canon EF 24-70mm f/2.8L USM, Canon EF 50mm f/1.4, Canon EF 85mm f/1.8 USM
cdifoto
Sep 29, 2007 15:15 |  #5
lukasgunar wrote in post #4032165 (external link)
Good luck.
lukas
You could do that, or just get a grey card and cut it down to a smaller pocketable size.
I have the whibal and never use it. The grey card does the same thing and was far less expensive.
1,151 views & 0 likes for this thread, 4 members have posted to it.
2291 guests, 129 members online
