Does someone know how to set the f-stop to 1.8 or do i need to buy another lens?Its for my class and im a noob.. please help
Sev0 Hatchling 4 posts Joined Sep 2007 More info | Sep 29, 2007 12:51 | #1 Does someone know how to set the f-stop to 1.8 or do i need to buy another lens?Its for my class and im a noob.. please help
LotsToLearn Goldmember 2,290 posts Joined Mar 2007 Location: GTA, Canada More info | Sep 29, 2007 12:55 | #2 Depends on your lens. Does it have that large of an aperture to begin with?
Sep 29, 2007 12:58 | #3 Its brand new its the one that comes with the K2 its says it a 29-90mm 0.38m/1.3ft .
crn3371 Cream of the Crop 7,198 posts Likes: 2 Joined Mar 2005 Location: SoCal, USA More info | Sep 29, 2007 12:59 | #4 You can only set aperture within the limits of the particular lens. Which lens are you trying to do this with? I'm assuming that it's one of the generic kit zooms sold with the entry level film cameras. In that case, the answer is no.
Sep 29, 2007 13:01 | #5
crn3371 Cream of the Crop 7,198 posts Likes: 2 Joined Mar 2005 Location: SoCal, USA More info | Sep 29, 2007 13:05 | #6 With that lens, definately no. On your lens it probably says something like f3.5-f5.6. Those are the widest apertures available on that particular lens. At the widest zoom (28mm) it's at f3.5 , and zoomed out to 90mm the widest aperture available jumps up to f5.6. If your class assignments require you to shoot at f1.8, then you need something like the Canon 50mm f 1.8 , which goes for about $70.
Sep 29, 2007 13:10 | #7 crn3371 wrote in post #4031827 With that lens, definately no. On your lens it probably says something like f3.5-f5.6. Those are the widest apertures available on that particular lens. At the widest zoom (28mm) it's at f3.5 , and zoomed out to 90mm the widest aperture available jumps up to f5.6. If your class assignments require you to shoot at f1.8, then you need something like the Canon 50mm f 1.8 , which goes for about $70. Thank You for all your help he's got me taking less depth of field pics right now he used Duane Micheals as an example.Your help was much appreiciated.
crn3371 Cream of the Crop 7,198 posts Likes: 2 Joined Mar 2005 Location: SoCal, USA More info | Sep 29, 2007 13:14 | #8 Good luck with your class, and a belated Welcome to the Forum!
Biko Senior Member 639 posts Joined May 2003 Location: Bradford England UK More info | You can still use your lens for less DOF just set at widest setting bearing in mind it will change as you zoom f3.5-f5.6.
| Latest registered member was a spammer, and banned as such! 2921 guests, 169 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
