Thread started 29 Sep 2007 (Saturday) 20:12
Upgrade 20D to a 5D?
lear35man
Sep 29, 2007 20:12 |  #1
SeattleSpeedster
Gallery: 874 photos
Sep 29, 2007 20:22 |  #2
ok so what do you like to shoot?
Fuji GFX100s and A7R II | Zeiss 85mm f1.4 Otus and 28mm f1.4 Otus | Fuji GF23mm, GF45-100mm and GF32-64mm | Canon 200mm f1.8 Canon 70-200mm 2.8 ii | Zeiss 100-300mm | Zeiss 16-35mm f4 | Zeiss 135mm f2 | Zeiss and Sony 50mm f1.4 | Mavic 3 Pro and Inspire 2 X7 drones | https://mikereidphotog​raphy.com (external link)
dfindr
Sep 29, 2007 20:35 |  #3
What are you kidding, the 5D is a quantum leap in IQ from the 20D, and the 20D is not to shabby. If you can afford it get it no matter what you like to shoot. You will not be disappointed. Hang a 16-35 on it whether it be a I or II version, or you can even still find the 17-35 L, or if you want to go really crazy get the 14 mm f/2.8 and really go crazy wide.
DAVID ALAN DARBY // MAC CONVERT // Raging and unapologetic L'coholic constantly Striving To Measure Up to the Quality of My Gear!
Too Many Bodies, Way Too Much Glass, Not Enough Time . . . BUY THE BEST, BUY IT ONCE, GO TAKE PICTURES!
lear35man
Sep 29, 2007 20:42 as a reply to  @ dfindr's post |  #4
ed ­ rader
"I am not the final word"
Sep 29, 2007 22:25 |  #5
lear35man wrote in post #4033615 (external link)
I mostly do landscapes, a lot of outdoor stuff. I do a lot of aerial photography. I use a 70-200 on the 20d for that. Occasionaly I do some outdoor family/engagement type pictures. I find that I take very few indoor shots. Thanks for all the input.
that means you'll need a longer lens for your 5d or else you might want to consider keeping the 20d.
i went from the 20d to the 5d.
ed rader
5D4 x2, 16-35L F4 IS, 24-70L II, 70-200L F4 IS II, 100-400L II, 14L II, sigma 15 FE, sigma 28 f1.4 art, tc 1.4 III, 430exII, gitzo 3542L + markins Q20, gitzo GT 1545T + markins Q3T, gitzo GM4562
jdizzle
Darth Noink
Sep 30, 2007 01:16 |  #6
Keep the 20D and get the 5D for your wide angle shooting.
Psychic1
Gallery: 70 photos
Sep 30, 2007 08:38 |  #7
I love my 5D and the IQ is incredible, but I would probally go EF-S 10-22, keep the 28-70 and add a 70/200L and maybe a 40D and grip for not much more than a bare 5D, which will be superceeded next year.
1DsIII - 1D IV - 5DS R - IR Rebel -TS-E17L - 14L II - 35L - 135L - 400L 5.6 - 50 Compact Macro - Sigma 60 - 600 - 2 x 580EX II & CP-E3 - 270EX II - 1.4xII - 25mm Ext. - Angle Finder C - Induro/Induro - SkimmerPod II - Toshiba I7 - NEC Spectraview - Pro 9000 II
squiress
Sep 30, 2007 08:49 |  #8
Why not simply drop down to the 10-22 Canon lens. On the 20D you will get the equivalent of 16mm at low end and all the wide angle you could want. Certainly attractive economically.
Stew
My Stuff
Thoughts-Tripods-Ballmounts-Teardown(TD)Benro KB2 Ballmount
TD Weifeng FT-565H Ballmount-TD Benro C128, C328n6 Tripods
TD Dynatran AT-A105T Tripod-TD Benro MC-68n Monopod
johneo
Joined Aug 2003
Sep 30, 2007 09:02 as a reply to  @ Psychic1's post |  #9
I've had a 10D since July 2003. Never saw a reason to upgrade to a 20D ... not even a 30D for that matter. This past July I upgraded to a 5D. The 5D and 10D (likely 20D as well) are in completely different leagues, in my opinion.
TRUE wide angle! Even using my 17-40 on the 10D never seemed like wide angle ... just wider than anything else I had. Now it can be used for what it is.
A while before getting the 5D I also bought a 24-70 L. Nice lense on my 10D but 24mm isn't wide on the 10D. It's an even better lens and WIDE on the 5D.
I really don't know how to describe the difference and in fact consider that I am still learning how to use the 5D but when I shoot the same shot with both cameras ... there are noticable differences.
The one big difference I do notice is losing that "crop factor". While I get the feeling I've lost zoom, in reality, I could crop a 5D photo to do what my 10D does, or pretty close yet with better quality.
2 - 5DMKII's, Powershot SX 150 IS
7D, 5D, IR/5D, 10D, IR/10D, Elan 7NE
17-40 L, 24-70 L, 70-200 f/2.8 L IS, 100-400 L IS,
TS-E 24 f/3.5 L, 28-135 IS (x2), 50 f/1.8, 85 f/1.8 550EX, 430EX
40mm pancake
stuartf287
Joined May 2003
Sep 30, 2007 10:54 as a reply to  @ johneo's post |  #10
You should consider a Sigma 12-24 on a 5D. It doesn't get much wider than that. Some users describe the 12-24 as one of those lenses that come in "good" and "bad" units. I have one that I use primarily on 1.6 crop digital cameras, so I can't tell you how it works on a full frame. I have used it on a film camera, and the prints look good. The developer I use thought the shots were taken with a fisheye. Good luck!
icft
Joined Nov 2005
Sep 30, 2007 23:12 as a reply to  @ stuartf287's post |  #11
I recently got a 5D to go along with my 20D. The IQ of the 5D is truly amazing.
I already had a 24-70 2.8L and 70-200 2.8L IS, and my next glass will be long glass. 24mm on a full frame is wide.
Since I got the 5D the 20D has seen no use, but I expect it will get used when I have need to shoot very long. 200mm on a full frame is really short compared to on a 1.6 crop. I expect that would be your only complaint. Even then, the improved IQ makes it tough to complain. Keeping the 20D and getting the 5D might be good to start with. Then see if you need to keep the 20D and if you want any wider lenses.
Bamamike
Oct 06, 2007 18:27 |  #12
@stuartf287
I have tested the sigma 12-24mm on the 5D, it's a WOW lens, you are inside the picture
Two bodies left, some "soso" lenses, and still a lot of gear.....
ThomasOwenM
Oct 06, 2007 21:36 as a reply to  @ Bamamike's post |  #13
I'm also considering upgrading from a 20D to a 5D because sometimes I'm frustrated with the crop factor. Sometimes I can't go wide enough. However, I have read up on full-frame sensors and their problems with vignetting.
I'm wondering if 5D owners have run into vignetting problems. If so, are there some lenses the problem is better or worse on?
1D Mark III, Canon 50L f/1.2, Sigma 30 mm f/1.4 lens, Canon 85 mm f/1.8, 430 EX flash, ST-E2 Transmitter, Quantaray QSX 9500 tripod, Manfrotto monopod
new ­ at ­ this
Oct 07, 2007 00:15 as a reply to  @ icft's post |  #14
Jumping in here with a question -- I had a 20 D and bought my husband a 5D for his birthday. It's his first digital. Before he was using film and had three EOS bodies. We're having trouble getting the exposure right. I'm just learning about the RAW image processing so that may be part of the problem, but even though the playback on the 5D looks great, when we download the images most of his outside pictures are overexposed. He's stopped down but it's still off a bit. Haven't tried the gray card yet.
Anyone else had this problem?
rick ­ j
Oct 07, 2007 06:36 as a reply to  @ new at this's post |  #15
sorry for butting in but why is a 5d wider?? is this what you call a full frame lens? and if so what does that actually mean ?
www.ichiban-koi.co.uk (external link)
1D mk3, canon 17-35 L CANON 28-70L, canon 70-200 f2.8L IS canon 300 L f4 is, canon 100mm macro, 580EX SPEEDLITE, DYNATRAN AT-828, Giottos MM 9570
2,420 views & 0 likes for this thread, 17 members have posted to it.
2801 guests, 162 members online
