Thread started 30 Sep 2007 (Sunday) 04:24
Multi exposure
aymanmb
Sep 30, 2007 04:24 |  #1
Is it possible with the 400D to have multiple exposure on same frame/shot. We used to enjoy this with film Cameras and do a lot of trocks with it.
If yes, how?
Canon 50D | EF-S 17-55 f/2.8 IS | EF-S 55-250 IS | EF 50mm 1.8 | BG-E2N Battery Grip | 580EX II
*Sonic*
Sep 30, 2007 05:00 |  #2
I asked this question some time back on another forum, and I think the answer was to just use Photoshop or similar
Not sure if any DSLR's will let you do this type of shot, maybe one or two will but unsure
Canon 30D
Canon EF 50mm f/1.8 mkII
Canon EF 28-105mm f3.5-5.6 USM mkII
Canon EF-s 18-55mm f3.5-5.6 II
Canon EF 70-200mm f/2.8 L :lol:
Riff ­ Raff
Sep 30, 2007 05:15 as a reply to  @ *Sonic*'s post |  #3
Here's a Sports Shooter article about using multiple exposures on a Nikon D2X, I believe:
http://www.sportsshoot​er.com/news/1460 (external link)
They were using it for a three exposure (single photograph) pitching sequence.
Shawn McHorse - Shawn.McHorse.com (external link) / AustinRocky.org (external link)
DSLR: 5D Mark III Compact: S100 Flash: 580EX II Bag: Tamrac Rally 5
Lenses: 16-35mm f/2.8L II, 24-70mm f/2.8L, 70-200mm f/2.8L IS,
50mm f/1.4, 85mm f/1.8
FotOz
Sep 30, 2007 05:50 |  #4
Don't know about the 400D, but I know the 300 and 350 won't allow multis. Sensor isn't designed for it. I do multi's by shooting off a tripod, then Photoshopping the finals - something like these!
. . . Steve . . .
http://www.flickr.com/​photos/fotoshoppe (external link)
Fuji W3, Canon 400D, 450D, 550D+BGs. 2X1GB, 1x4GB and 1x16GB CF cards. 3X32GB SDHC and 4x8GB SDHC cards. 1X18-55 EFS lens. 1X28-105 and 1X75-300 USM Canon EF lenses. 1x18-200 IS Canon EFS lens. Canon Speedlite 380EX & Canon Speedlite 430EX II flashes. 1 x Rolleiflex and 1 x Rolleicord TLR cameras. i-phone5.
SoloDallas
Sep 30, 2007 05:59 |  #5
I think it's called bracketing. I have different cameras than yours which will allow for bracketing (and several types of it) but simulating bracketing as the poster above is a well known practice.
If I am not wrong, you take the same shot quickly underxposing and overexposing one or more stops below and above. Gotta be quick in changing the exposition if you don't have a built in bracketing function (which will shoot three expositions with one click).
Canon 1D MkIV | Canon 5D MkII | 17-40 f/4L| 50mm f/1.2L | 24-105 f/4L | 70-200 f/2.8L IS | 580EX II Speedlite | 100 Macro II f/2.8L
FotOz
Sep 30, 2007 06:44 |  #6
SoloDallas wrote in post #4035312 (external link)
No bracketing involved in these shots (although my cameras will do that.) These are just the combinations of a repetition of shots, being careful where the subjects are in each one. In the top example for instance, I used the first shot with the B&G in the centre as my main. I then tightly cropped and cut the B&G out of my second shot and pasted them to the first. Then tightly cropped and cut the B&G from the third shot and also pasted that to the first. This gave me a three layered shot. After I had zoomed in and accurately aligned the 2 added layers I merged them and there you are. Nothing magic, just fun. The B&G loved them.
. . . Steve . . .
SoloDallas
Sep 30, 2007 07:27 |  #7
Yes FotOz, I hand understood your technique and liked it lots, too!
rangersvtsplash
Joined May 2003
Sep 30, 2007 07:42 as a reply to  @ SoloDallas's post |  #8
40d do this? or even have like panarama feature?
Canon EOS 40D + BG-E2 Zoom Lens EF-S 17-85mm 1:4-5.6 IS USM with EW-71B Hood, 50mm f1.8 II.
John_B
Gallery: 178 photos
Sep 30, 2007 08:00 |  #9
aymanmb,
Theoretically its possible to do multi exposures on a DSLR, however it is not the same as with film (you can't open and close the shutter for the same photo on DSLR's). The way it can be done on a DSLR is by taking a long exposure (very long exposure and best if you have a external shutter cord) and put the lens cover on change the subject then take lens cover off again. Having a flash that can be fired manually at low power also can aid in the exposures, like in the first photo I posted.
Here are some examples of how I did it.
This one I only have one stuffed animal but I got this.
Seeing Double!
IMAGE: http://johnbdigital.com/special_beauty/seeing_double.jpg
click for specsIMAGE LINK: http://johnbdigital.co​m …_beauty/seeing_​double.htm  (external link)
Here is a photo of only 1 TV but changed the channel and repositioned my tripod before each time I took the lens cap off
Mult Exposure TV
IMAGE: http://johnbdigital.com/special_beauty/multi_tv_exp.jpg
click for specsIMAGE LINK: http://johnbdigital.co​m …l_beauty/multi_​tv_exp.htm  (external link)
So it is kind of possible :)
click to see (external link)
racingsafetyman
Sep 30, 2007 09:35 |  #10
Bracketing AEB will not take three shots with one click, it requires you to press the shutter three times, one at "correct" exposure, then one under and one over-exposed by however many stops you have set it to.
Colin
My Gear List
http://www.colantra.sm​ugmug.com (external link)
SoloDallas
Sep 30, 2007 09:37 |  #11
racingsafetyman wrote in post #4035970 (external link)
True that. My bad. Bracketing and multiexposure are two different things. Got confused, apology :)
Hermeto
Sep 30, 2007 09:40 |  #12
Only if Drive mode is set to Single shooting.
With Continuous shooting, you have to press shutter button only once and keep it pressed until all 3 shots are fired.
(Pg. 91, EOS 350D Instruction Manual)
*Sonic*
Sep 30, 2007 12:43 |  #13
Hermeto wrote in post #4035992 (external link)
That will explain why bracketing wouldnt work properly for me the other evening then :)
Canon 30D
racingsafetyman
Sep 30, 2007 14:07 |  #14
OK, that's cool I didn't know that :)
Colin
My Gear List
Sageg
Sep 30, 2007 14:14 |  #15
I'm pretty sure some of the Nikon dSLRS can do multiple exposures. I've seen some really interesting abstract done using this technique and a Nikon.
Sarah
Eyes, hands, brains, legs
5,702 views & 0 likes for this thread, 11 members have posted to it.
Multi exposure
2641 guests, 160 members online
