Thread started 30 Sep 2007 (Sunday) 16:48
350d problem
Liam:
Sep 30, 2007 16:48 |  #1
My 350d is starting to die, here are my problems:
Turns on and shows the "err 99"
Wont lock on focus continues to hunt, then will crash on the menu (even if I turn it off it still shows the menu) I have to take the battery out.
Does anyone know whats wrong with it? It occurs when any one of my lenses is attached.
Thanks for any help.
Liam.
gear
http://sussexbirdphoto​graphy.blogspot.com/ (external link)
number ­ six
fully entitled to be jealous
Sep 30, 2007 17:44 |  #2
Could be something as simple as a bad battery. You can't be sure unless you try a known good one.
-js
"Be seeing you."
50D - 17-55 f/2.8 IS - 18-55 IS - 28-105 II USM - 60 f/2.8 macro - 70-200 f/4 L - Sigma flash
Box ­ Brownie
Sep 30, 2007 17:46 |  #3
Hi Liam
err99 as I am sure you know is a sort of "catch all" code that covers everything.
The fact that it is happening with any lens and then reverts back to the menu is obviously worrying.
Were I seeing the same I perhaps would do the only other thing an owner can do before sending it to the Canon 'doctor', try replacing the button cell backup battery. This may just possibly be indicated if when you say 'it crashes to the menu screen....' is that the one that invites you to set the date up?
Oh, have you tried with the CF card taken out/in ?
Hope that helps maybe? And that you can get sorted ASAP.
That was a great meal ~ you must have a good set of pans :p
Images for a photographic memory (external link) | Flickr (external link) | >>>My 500px<<< (external link)
credit line is vanity, payment is sanity
Liam:
Oct 01, 2007 02:02 |  #4
Box Brownie wrote in post #4038256 (external link)
Hi Liam
Hi thanks or the info,
whats the button cell backup battery?.
It sometimes crashes when ooking at photos sometimes when I am changing settings e.g. iso..
I have tried changing the battery but I will try it with a different cf card. I used the camera in rain last weekend, do you think that could be something to do with it.
thanks.
Liam.
gear
Mannytkd
Oct 01, 2007 02:33 |  #5
Liam: wrote in post #4041142 (external link)
thanks.
You say you used it in the rain.....mmmm, that could well be your problem and you may have damaged the circuits??
As far as the button battery, it's where you insert your main batter, you'll see a very small serated finger finger grip, but i think there's a little safety catch that ou have push in first to be able to remove it......??
Canon 50D | [COLOR=black]18-55 IS | 55-250 IS | Canon EF 100mm USM macro | Canon 50mm MK2 | Tokina 11-16 | Kenko Auto Extension Tubes | Uniloc 1200 series pod | Canon 430EX flash gun | Some filters
www.karls-photography.co.uk (external link)
Box ­ Brownie
Oct 01, 2007 02:34 |  #6
thanks.
The butten cell backup battery is accessed in main battery compartment - if you look (carefully) there is section of plastic marked something like CRxxxx (x = numbers) this I think is slide carrier and 'pulls' out. The manual I am sure mentions it.
As for the effect of rain, for sure it could cause any range of problems. Light drizzle and wiping regularly I have found on the one occassion I used it "wet" was OK but the 350D is not weather sealed so if you got it very wet i.e. water pooling on the top surface etc then water ingress is very likely and could damage the internals.
769 views & 0 likes for this thread, 4 members have posted to it.
350d problem
2634 guests, 160 members online
