Thread started 01 Oct 2007 (Monday) 11:58
Need some help on this Bride
zachwsu
Oct 01, 2007 11:58 |  #1
This is a photo at a recent wedding i was in and took some shots as we were all hanging out. I need some help on how best to handle this kind of lighting. I used the rebel XT with a lightsphere and the 430ex, but as you can see, when i go to process this its either that the ocean behind her will be blown out or she will be totally underexposed. I am no master at lighting but any tips would be awesome. Thanks!
http://www.zachanderso​n.com (external link)
http://www.zachanderso​n.net (external link)
Canon 5D Mark II | Canon 40D | Rebel XT backup | 24 1.4L | 17-40L | 50mm 1.4 | 85 1.8 | 580 ex II | 430ex | Nikon SB-28 | 3 Elinchrom Skyports Triggers |
Mario.
Oct 01, 2007 12:00 |  #2
I would create three different exposures from the RAW file, merge them into a single photo, and start to paint in where it needs help.
Mario M. | Black Macbook 2.4/ 4GB | 40D | 350D| 17-40 f/4L | 70-200 f/4L | 580EX | 430EX
Dream ­ Merchant
Oct 01, 2007 12:32 as a reply to  @ Mario.'s post |  #3
Basically a lot more fill flash and/or a reflector (if you have an assistant) and a smaller apeture could have been used, or adjust the different areas in post work.
I had a quick bash at editing your photo to give you an idea of what more fill light could have achieved. CHEERS!
IMAGE: http://clprodn.smugmug.com/photos/202760552-M.jpg
Editing welcome :D
CheetaPita
Oct 01, 2007 12:41 |  #4
i tried.....im not that great at editing...i think i oversaturated her skin a little
http://carleymacphotog​raphy.blogspot.com/ (external link)
zachwsu
Oct 01, 2007 12:55 |  #5
thanks for help, these are a couple of good attempts. I usualy got the same result.
hawk911
Oct 01, 2007 13:02 |  #6
Can you layer the BG and the bride separately and adjust that way?
HAWK Photography Gallery (external link) FB Fan page (external link)|_My gear: 5d3, 70D & 40D (all gripped), 580exII, 550ex, Canon 24-70 L & 85 f1.8, 50mm f1.4; Tamron 70-200 SP Di VC, Canon 18-55, Sigma 1.4xtc; Elinchrom Whore, Skyport triggers, Speedotron BD and Kacey Grid, Vagabond minis
Maureen ­ Souza
Oct 01, 2007 13:21 as a reply to  @ hawk911's post |  #7
I'm not sure this was successful but I tried to cut down on the background glare and bring her face out a bit more.
5DMK4
7DMK2
dseered
Oct 01, 2007 13:24 |  #8
I have to say I like the original you posted !
Canon 1DMk111,Canon 40d, Canon 100-400 4.5-5.6L, Canon 70 - 200 2.8 IS L, Canon 17-85 1.4-5.6 IS USM, Canon 50 1.8, Tamron 70-300, Canon 2x Teleconverter, Canon 580ex11 Speedlite, Portaflash mini portable studio.
jbdial1515
Oct 01, 2007 13:24 |  #9
That is what I was thinking...You could create a new layer, select the background and adjust the exposure/brightness etc...You could then select the inverse and adjust her accordingly.
Just my thoughts.
30D | Canon 70-200 f/4 L | Canon 24-105 f/4 L | Canon 580EX II and 500 DG Super
chickymcnuffin
Oct 01, 2007 14:32 |  #10
Here's what I came up with... Not sure if it's any better or not...
IMAGE: http://i37.photobucket.com/albums/e76/chickymcnuffin/photo%20edit/IMG_5674-2.jpg
<>< Amanda ><>
Curtis ­ N
Master Flasher
Oct 01, 2007 14:38 |  #11
zachwsu wrote in post #4043253 (external link)
Get rid of the Fongware when you're outdoors. It takes a lot of flash to compete with the sun, and even more to compete with an extremely bright background like this. Direct flash is the only thing that works in that situation.
jschro
Oct 01, 2007 14:40 |  #12
I'm not too put off by the original, nice shot in it's own right. How did you expose the shot? Not having been in that situation yet I think I would have underexposed by 2/3 stop (maybe a full stop) and used fill flash to get her to pop. Having a white dress...does that not work as well?
Anyway, did a quick edit myself.. duped layer, levels adjustment for water, layer mask paint out bride, merge, duped layer, shadow/highlight adjustment for the bride, layer mask to reveal brides skin.
Curtis ­ N
Master Flasher
Oct 01, 2007 14:48 |  #13
jschro wrote in post #4044257 (external link)
A lot of white on the subject will affect the E-TTL metering an usually you'll need some +FEC to compensate. But I agree that shot should look pretty nice in print.
GyRob
Oct 01, 2007 15:04 |  #14
I used the shadow/highlight tool then ajusted color balance then a bit of curves.
Rob.
"The LensMaster Gimbal"
SteveG
Oct 01, 2007 15:14 as a reply to  @ GyRob's post |  #15
Here's my go at it; made multiple layers to adjust levels and curves and added a blue photo filter to the sea.
IMAGE: http://i119.photobucket.com/albums/o126/Oak-Street-Imaging/IMG_5674a.jpg
Steve
EOS 40D & grip, EOS 300D and grip, Kit Lens, EF 17-40 L, EF 50mm 1.8, EFS 60mm Macro, EF 55-200mm II USM, Sigma 50-500 OS, 430EX Speedlight,
3,035 views & 0 likes for this thread, 19 members have posted to it.
Latest registered member is RawBytes
1537 guests, 164 members online
