Thread started 01 Oct 2007 (Monday) 16:22
Walking around with camera on ... bad for it?
jtown
Oct 01, 2007 16:22 |  #1
I've noticed when I walk around with my 40D (especially on a jolty stroll downhill) that the mechanics inside the lens move around a bit. Is this harmful to it? Do you guys usually turn the camera off when you're not using it and walk around?
Tsmith
Formerly known as Bluedog_XT
Oct 01, 2007 17:00 |  #2
Mine stays on when in the field. Just set the standby mode to a shorter time if its a concern.
AdamLewis
Oct 01, 2007 17:04 |  #3
jtown wrote in post #4044803 (external link)
The mechanics in the lens move around a bit? ???
Are you saying theyre just freely moving? Or you keep accidentally bumping the shutter button to make it AF or engage IS?...
Bukka
Oct 01, 2007 17:07 |  #4
Mine goes into standby after 1 min, and i usually never touch the on/off switch.
Switched to the "dark side" but I like these boards.
Digital: Nikon D200
Lenses: Nikkor 50 1.8D, Nikkor-P 55 macro 3.5, Nikkor 35 1.8G Nikkor 85 1.8.
Film: Canonet QL17 G-III, Bell&Howel/Canon Dial 35,
segasaturn
Oct 01, 2007 17:10 |  #5
I'm fine walking or even jogging with a camera. Not like I'm in workout clothes jogging, but if I need to get to another location quickly, I'll run with camera in hand.
kcbrown
Oct 01, 2007 17:27 |  #6
The only disadvantage to using a short standby on the 40D comes when you're using one of the custom user modes on the dial. When the camera comes out of standby, everything will be set back to the settings you saved to that mode, including exposure (if you saved from manual mode) or exposure compensation (if you saved from aperture priority, shutter priority, or program modes).
This, in my opinion, is a bug. The camera should distinguish between being power cycled via the on-off switch and coming out of standby.
My solution to this is to set the standby time relatively high for the custom user modes. With it set up that way, if I'm going a long enough time between shots that the camera drops into standby, the chances are very good that the shooting conditions have changed significantly enough that I'd have to fool with the exposure settings anyway.
"There are some things that money can't buy, but they aren't Ls and aren't worth having" -- Shooter-boy
Canon: 2 x 7D, Sigma 17-50 f/2.8 OS, 55-250 IS, Sigma 8-16, 24-105L, Sigma 50/1.4, other assorted primes, and a 430EX.
Nikon: D750, D600, 24-85 VR, 50 f/1.8G, 85 f/1.8G, Tamron 24-70 VC, Tamron 70-300 VC.
jtown
Oct 01, 2007 17:53 |  #7
I'm not sure what I feel moving, but no I'm not focusing. It's only when I'm walking downhill because of the jolting steps and happens when it's either on or off. Anyway it was just a minor concern that I won't let bother me.
tmcman
Oct 01, 2007 18:05 as a reply to  @ jtown's post |  #8
I know my Tamron lens will zoom out after long bouts of walking.
So often I zoom it in and lock it when I'm on the move.
Comments, Questions, Observations Welcome
Fuji X-T2, 18-55mm, Gitzo 1541 w/ Markins M10 ballhead.
"Art always shows itself by doing much with few and simple things." Arthur Wesley Dow
forno
Oct 01, 2007 18:23 |  #9
Tsmith wrote in post #4044983 (external link)
Mine too, no issue AFAIK
Canon 350D -EF-S 10-22 l EF-S 17-55 l EF 50 f/1.8 l EF 70-200 2.8 IS l 430EX l
Fornography (external link)
AdamLewis
Oct 01, 2007 18:25 |  #10
jtown wrote in post #4045296 (external link)
I just dont understand what you mean by stuff "moving" or "jiggling", especially when you couple that with asking about it being on. The only time anything should move when the camera is on ( as opposed to being powered off ) is the AF and/or IS motor...neither of which should be "jiggling".
MaDProFF
Oct 01, 2007 18:27 |  #11
Does it not go in to like sleep mode after a while anyhow?
but I leave it on all the time, when I am using it anywhere.
Photographic Images on Brett Butler (external link) px500 (external link) & Flickr (external link) Some Canon Bodies , few blackish lenses, A dam heavy black one, couple dirty white ones, a 3 legged walking stick, a mono walking stick, and a bag full of rubbish :oops:
And Still Learning all walks of life, & most of all Photography.
AperturePriority
Location: Beautiful, Sunny, and Warm Southern California!
Oct 01, 2007 18:29 |  #12
I feel the same thing. It feels like a gyroscope inside either the body or the lens. I thought it may be the IS mechanism in the lens, but isn't it suppose to not be in IS mode until the shutter is half-way pressed?
-Canon EOS 40-D with vertical/battery grip, wireless remote shutter release
-Canon 10-22mm F3.5 USM (with hood)
-Canon 70-300mm F4 EF IS USM (with hood)
-Canon 28-135mm F3.5 EF IS USM (with hood)...and many more items.
-Check out my photography here (external link). And here (external link), too.
tsfall
Oct 01, 2007 18:30 |  #13
I think what the OP is referring to is "Zoom Creep" - when a zoom lens creeps from one zoom extreme to the other due to slight jarring downwards movements when walking. I know this used to happen with my 55-200 (I soon figured out why, it was a c**p lens) and can easily happen with Push-Pull lenses like the 100-400
Regards
Tom
Canon 40D [Gripped]
Canon 18-55 f/3.5-5.6
Canon 35-80 f/4.0-5.6 [Macro Modded]
Canon 24-105 f/4 L IS
Canon 70-200 f/4 L
basroil
Oct 01, 2007 18:35 |  #14
sometimes you'll hear a small clink or thud when jotting the camera around. this is normal. that is the vertical/horizontal sensor moving around (best way to describe it is as a ball in a diagonal tube. when the camera is horizontal, the ball is on the bottom, when it is vertical, the ball moves to the right side of the camera, which happens to be on the bottom, though it is actually more complex than just a ball in a tube). just keep doing your thing and everything's fine
cdifoto
Don't get pissy with me
Oct 01, 2007 18:38 |  #15
I think what you feel/sense moving around is that anti-dust shake system. It's NOT harmful to carry your camera around while it's on.
2,376 views & 0 likes for this thread, 17 members have posted to it.
2677 guests, 167 members online
