Thread started 03 Oct 2007 (Wednesday) 11:07
Focusing Problem
grandadraymond
Oct 03, 2007 11:07 |  #1
Help!! Please, its been very overcast and raining, i was using my 350D and sigma lens, taking a bird table at approx 12 feet because of the rain i was sat in the car with the window down, and no way could i focus on the table, i did manage 3 half decent shots by focusing on the ground then with shutter button half pressed, i brought the camera up to the bird table it was still in focus then i took a shot, is the problem me, or the lens, or the 350D any advice would really be appreciated , thank you...Ray
aligater
Oct 03, 2007 11:15 |  #2
Ray,
has the lens you are using got a distance setting ?
CarLton.
grandadraymond
Oct 03, 2007 11:22 |  #3
i really dont understand, but if you can give me it in simple terms i will have a look...Ray
aligater
Oct 03, 2007 11:27 |  #4
Ray,i don`t know the lens you are using but from your signature you have a 70 - 300 macro.Just wondering if you have it set for macro.
CarLton.
grandadraymond
Oct 03, 2007 11:28 |  #5
The lens has distance scale numbers round it does that tell you anything aligater
grandadraymond
Oct 03, 2007 11:35 |  #6
no it wasnt set for macro, but i think im begining to understand now, ive just been outside and had the same problem, then i adjusted the the scale ring and i got it focused, do you think that was my problem aligater, if it was im very grateful to you ...Ray
aligater
Oct 03, 2007 11:37 |  #7
Ray pasted off Sigma site...........Sigma 70-300mm DG Macro Zoom Lens is capable of macro photography with a 1:2 maximum close-up magnification at the 300mm focal length. The minimum focusing distance of Sigma 70-300mm DG Macro Zoom Lens is 1.5 m at all zoom settings. Sigma 70-300mm DG Macro Zoom Lens also has a switch for changeover to macro photography at focal lengths between 200mm and 300mm with a maximum close-up magnification from 1:2.9 to 1:2 and a minimum focusing distance of 95cm. Without changing the distance between camera and subject, you can change the shooting magnification of Sigma 70-300mm DG Macro Zoom Lens.
Have you set the switch to the macro setting ? or is set to MF ?
CarLton.
basroil
Oct 03, 2007 11:37 |  #8
it's probably set on MF right now... make sure the switch is on AF
grandadraymond
Oct 03, 2007 11:47 |  #9
The camera was on auto focus, and the macro wasn't on, ive just found the AF point on the camera was set to the far left would this give me this problem guy's
JackProton
Oct 03, 2007 14:54 |  #10
The camera needs contrast - lighter and darker areas - for a good focus lock. I would speculate that the combination of low-light conditions, rain and the lack of contrast of the subject itself contributed to the camera's inability to achieve focus lock. Your 70-300mm F4-5.6 lens is also a bit slow at 300mm with an f5.6 maximum aperture meaning its just not going to work very well in these sorts of low-light low-contrast conditions.
Mark_Cohran
Joined Jul 2002
Oct 03, 2007 15:00 |  #11
grandadraymond wrote in post #4056538 (external link)
Yes, especially if that focus point was off to the side of where you were actually trying to focus. Then, when you pointed the lens at the ground, that particular focus point was in the same plane of focus as the others and you could set focus and recompose.
Mrak
Mark
Some primes, some zooms, some Ls, some bodies and they all play nice together.
Forty years of shooting and still learning.
My Twitter (external link) (NSFW)
Follow Me on Instagram (external link)
grandadraymond
Oct 03, 2007 15:39 |  #12
Thank you very much friend's youve learned me a lot
Box ­ Brownie
Oct 03, 2007 19:26 |  #13
I suggest you select the "centre focus point" for most of the images you are likely to take. For the exceptions select one of the others as needed but IMO avoid letting the camera pick the focus point(s).
Just my 2p's worth.
That was a great meal ~ you must have a good set of pans :p
Images for a photographic memory (external link) | Flickr (external link) | >>>My 500px<<< (external link)
credit line is vanity, payment is sanity
1,276 views & 0 likes for this thread, 6 members have posted to it.
Focusing Problem
2677 guests, 166 members online
