Thread started 03 Oct 2007 (Wednesday) 14:13
Problems with Raw files
Nobi
Oct 03, 2007 14:13 |  #1
I'm using my 20 D since 1 year but now I get a lot ( min 1/3 of a 2 gig card) of compromised images (can't open ) or images are having on the side or bottom huge distructions.
What has changed? Any suggestions?
View corrupted images http://www.flickr.com …03/sets/7215760​2247288920 (external link)
Thanks for your help
S.Horton
Oct 03, 2007 14:16 |  #2
What software are you trying to use to open the RAW files?
Sam - TF Says Ishmael
:cool:
Nobi
Oct 03, 2007 14:19 |  #3
Lates Canon utility and Canon pp software
S.Horton
Oct 03, 2007 14:21 |  #4
Can you post results as JPG, or take a screen shot of what you're seeing?
And, if you shoot in RAW + JPG, does it happen only to the RAW result?
:cool:
Nobi
Oct 03, 2007 14:22 |  #5
How do I post pictures?
No I only shoot raw
angryhampster
"Got a thick monopod?"
Oct 03, 2007 14:22 |  #6
jpg files look fine? Perhaps make sure your firmware isn't corrupted and reinstall it. Format your memory cards as well.
Steve Lexa
Iowa City Wedding Photography (external link)
ST77
Oct 03, 2007 14:27 |  #7
Are you maxing out the cards space when shooting? If so that could be corrupting some of the data as the shots left on a card when shooting raw are only estimates.
My Gear: 1D Mark III,30D, 24-105 f/4L IS, 70-200 f/2.8L IS, 85mm 1.8, 100mm 2.8 Macro, 580ex II Flash 430ex Flash lowepro AW 300.
My spot on the web: www.st-77photo.com (external link)
Nobi
Oct 03, 2007 14:43 |  #8
No I don't.
You can see some corrupted pictures @
Jon_Doh
Oct 03, 2007 14:46 |  #9
Try reformatting your card. If you've done a lot of erasing data trails remain and can become corrputed. Reformatting should solve the problem.
I use a Kodak Brownie
S.Horton
Oct 03, 2007 14:49 |  #10
EDIT: if you search this forum for 'corrupt pictures' or 'corrupt files' you may find others who have had hardware problems cause this to happen. One talks about USB errors in transport from the CF, another about a bad RAM chip in the PC itself. This might be hard to track down.
Can you try import/view with DPP on another PC?
:cool:
JasonSTL739
Oct 03, 2007 15:14 |  #11
What kind of card are you using? I've had issues with off-brand cards. Not worth the "savings"
Also - you should be formatting your card everytime you use it back in the camera from emptying it. The camera format, not the computer. I've never had a corrupt image on my Sandisk cards, and the ones I'm using now have had probably 30k images through the three main 4GB cards I use in the last 9 months or so. I had one card that wouldn't read ONCE, and the Sandisk software was able to recover all the images without issues.
http://www.sedura.com (external link)
Nobi
Oct 03, 2007 15:24 |  #12
I used a 2 GB ScanDisk Ultra II and had the issue also with 1 GB Lexar card.
I did not reformat the card before use.
When I shoot 5 picture in a row (same scenario) I only got 1 out of it.
It is either a picture like see original post, or massage that the file is corrupted and can not be opened (or converted to Jpeg...)
JasonSTL739
Oct 03, 2007 16:24 |  #13
Nobi wrote in post #4057807 (external link)
Hmm two cards are doing this?
Can you repeat it - like format the card in the camera and shoot a bunch, will it still give you corrupt images?
superdiver
Oct 03, 2007 16:34 |  #14
Also, maybe try these cards on a different camera as well...Sounds to me like the cards are bad...
40D, davidalbertsonphotography.com
Newbie still learning
thatkatmat
Gallery: 41 photos
Oct 03, 2007 16:35 |  #15
are you saving to a portable hard drive then downloading onto your pc for editing?
My Flickr (external link)
Stuff
1,555 views & 0 likes for this thread, 10 members have posted to it.
2681 guests, 167 members online
