Thread started 03 Oct 2007 (Wednesday) 15:05
Lens Reversing
zucchini
Oct 03, 2007 15:05 |  #1
If I am reversing a 50mm and attaching it to a 100mm macro lens, where should I set my focus at on the 50mm? Is autofocus still available? If I am manual focusing do I use the 50 or the 100?
Also, would it be better to use the above setup or add extension tubes to the 100mm?
Thanks much,
zucchini
A Camera ~ A Lens ~ A Flash ~ A Tripod
http://www.zandecki.ne​t (external link)
LordV
Oct 03, 2007 15:16 |  #2
zucchini wrote in post #4057674 (external link)
Thanks much,
zucchini
You normally set a reversed lens like that at infinity focus and the aperture wide open. Af may be available- depends on the light. It's easier though to preset the magnification (on the macro lens) and focus by moving the camera.
Using a reversed 50mm like that will give you about 3:1 magnification with your 100mm macro. Using a full set of kenko ext tubes will give you a max of 2:1 and probably better IQ. You can use both together and get to 4:1 :)
Brian V.
Macro Hints and tips
macro ­ junkie
Oct 04, 2007 00:59 as a reply to  @ LordV's post |  #3
do u need the ring that the 100mm scrws on to the 50mm..i have 1 spare...if u need it let me know..u can have it;)
Uk prayingmantis forum - http://www.dragonscres​t.co.uk/forums/index.p​hp (external link)
My flickr gallery -http://www.flickr.com/​photos/hooked_on_macro​/ (external link)
DA Gallery where i sell prints - http://macrojunkie.dev​iantart.com/ (external link)
MPE-65MM - MT-24EX Twin Macro Flash (diffused with 2 X Gary Fong Puffer diffuser)
EF-S 60mm f2.8 USM - 430ex (diffused with lumeriqest soft box)
1,051 views & 0 likes for this thread, 3 members have posted to it.
Lens Reversing
2801 guests, 132 members online
