Thread started 04 Oct 2007 (Thursday) 08:32
Some flys from yestreday and 1 wasp
macro ­ junkie
Oct 04, 2007 08:32 |  #1
some flys from shooting in my garden yesterday..Every pic was hand held..when im off the floor i find it very hard to get the eyes spot on.i just cant seem to use them poles or the bazooka that delantech uses...mayby more practice is needed..mayby i need one of them things lordv uses?
IMAGE: http://farm2.static.flickr.com/1056/1483136630_67d19d0227_b.jpg
IMAGE: http://farm2.static.flickr.com/1152/1483138314_9d29bcdb9a_b.jpg
IMAGE: http://farm2.static.flickr.com/1177/1483134158_09619b4cfe_b.jpg
IMAGE: http://farm2.static.flickr.com/1359/1483134738_263fcd0cae_b.jpg
and a dead fly at 5:1
IMAGE: http://farm2.static.flickr.com/1138/1482280053_459498ac7a_b.jpg
Uk prayingmantis forum - http://www.dragonscres​t.co.uk/forums/index.p​hp (external link)
My flickr gallery -http://www.flickr.com/​photos/hooked_on_macro​/ (external link)
DA Gallery where i sell prints - http://macrojunkie.dev​iantart.com/ (external link)
MPE-65MM - MT-24EX Twin Macro Flash (diffused with 2 X Gary Fong Puffer diffuser)
EF-S 60mm f2.8 USM - 430ex (diffused with lumeriqest soft box)
Attic
Oct 04, 2007 08:54 |  #2
Nice detail in these MJ shame about the last one being blown out though.
Alby
racketman
Gallery: 20 photos
Oct 04, 2007 09:00 |  #3
masocistic wasp! 1 Muscidae family, 2 Dung fly 3 Flesh Fly. Main thing for eye detail is to keep aperture fairly wide ie around f8. Can't read EXIF on your images.
Toby
macro ­ junkie
Oct 04, 2007 09:30 |  #4
racketman wrote in post #4062317 (external link)
u can always go to my flick acount if u have a few mins..i would really appircate your input on them.all the exif info is in flick,i shot the last pic at fstop 14 i think.i was doing a test,,didint come out too good tho.
macro ­ junkie
Oct 04, 2007 09:31 |  #5
Attic wrote in post #4062288 (external link)
what do u mean by blown out?
Omri ­ Alon
Joined Nov 2005
Oct 04, 2007 09:52 |  #6
Excellent series :D
Omri Alon | Flickr (external link)
Canon 6D
Samyang 14mm | 16-35L IS | Rokinon 24mm | 35mm IS | 85mm f/1.8 | 200mm f/2.8L | 430EXII
LordV
Oct 04, 2007 12:55 |  #7
Excellent series- esp like the wasp - just missed eye detail on the flies (apart from the dead one)
Brian V.
Macro Hints and tips
Peepaw
Oct 04, 2007 14:49 as a reply to  @ LordV's post |  #8
Nice job mj. Seems like everyday the bar is being raised another notch around here.
Scott
Canon 30D/5D
macro ­ junkie
Oct 04, 2007 17:02 |  #9
LordV wrote in post #4063564 (external link)
Brian V.
how did u mean your pole?
TMT
Oct 04, 2007 17:09 |  #10
I love #1 and 2. Excellent shots.
S7000
My brain hurts
Oct 04, 2007 18:13 |  #11
Speaking of DIY setups...This is what I came up with. Basically, I went to the Hardware store and found a 'O' bolt that screwed into the tripod mount. Then went into my garage, found a piece of aluminum pipe. Sanded down the end so the 'O' ring could fit over it, attached that, then bent the inside of the pole out for an even snugger fit. The pole then fits over a bamboo stick used for holding up plants. The grip came off a 500watt light I used to make a light-box with. Works really well, it can basically hold what ever weight the screw can hold at the moment it'd be just under 2kgs, has no bend or movement...
LordV
Oct 05, 2007 02:25 |  #12
macro junkie wrote in post #4064970 (external link)
I just use a plastic coated metal bean pole or a collapsable tent pole. Both about 7 feet tall- just grip the pole in the left hand at the required height and grab a bit of camera aswell (sometimes the lens, sometimes the flash bracket). Works pretty well upto 3:1 with some practice. For shots above that I'm normally resting the camera lens on something (either the same surface as the bug or often a bit of me).
Brian V.
roli_bark
Oct 05, 2007 02:48 |  #13
You may have to tweak sometimes your FEC
5th is blown significantly
3rd is blown partly
1st is blown slightly
2nd & 4th are great.
dreamline
Oct 05, 2007 03:39 as a reply to  @ roli_bark's post |  #14
Nice detail in these M-J.
I'll go for the wasp.
When Alby says #5 is blown out, he means it's over-exposed. You cannot see any detail in the top left of the photograph owing to uneven lighting/reflection.
Bernie (external link)
Kit list:
dpastern
Oct 05, 2007 08:27 |  #15
#1 looks slightly blown to me
#2 looks fine
#3 slightly blown on the face, but very hard to avoid with this type of fly
#4 looks fine to me
#5 - badly blown
Fly shot in #2 could be better composed, and #5 is a bit soft, but other than that, they're pretty good shots.
Dave
2,002 views & 0 likes for this thread, 11 members have posted to it.
2789 guests, 131 members online
