Thread started 04 Oct 2007 (Thursday) 11:22
[REVIEW] In-Depth Review of the ThinkTank Speed Racer
nutsnbolts
Oct 04, 2007 11:22 |  #1
Today's review will cover the ThinkTank Speed Racer. (ThinkTank Speed Racer Link (external link)) I apologize for the images but it was done on a P&S. Hopefully, it's enough to get the point across.
What is it (per ThinkTank Website)?
Maximum capacity for a belt pack! Holds a Pro size SLR with lens attached and a 70- or 80- 200 2.8 next to it.
HTTP response: NOT FOUND | MIME changed to 'image/gif' | Redirected to error image by ADVERTISEMENT
Dimensions
Product Includes:
Pixel Pocket Rocket, Seam-sealed raincover, Accelerator Shoulder Strap
Internal Dimensions:
11" L x 6.25" W x 10.25" H
(28 x 16 x 26 cm)
External Dimensions:
12.5" L x 8.75" W x 10.75" H
(32 x 22 x 27 cm)
Review
For the most part, a review for this Speed Racer is very limited, at least, in terms of attaining any pictures to visualize what is to be expected. A couple of reviewers from CamBags depicts it nicely, however, if you wanted actual personal reactions, it's very limited.
To say the least, I'm very pleased with the purchase. I was looking for a bag that can accommodate two bodies, both with grip and lens attached. Not many bags out there can meet the requirements and from the top of my head, the Crumpler Brazillion Dollar Home fits the bill, however, it is quite large from what I have read. Of course, it can be subjective especially from what I have read as well with the Speed Racer, the size of the Speed racers from reviews states, "it's quite large".
What is large?
Well, for one thing, one of the other requirements I had was that it had to be a walk-around bag. I can see the benefits of the Crumpler Brazillion but from its sheer size, it is not recommended.
This leads me to entertaining the idea of the Speed Racer.
Before we begin, I think I will point out that there is a big misconception regarding the ThinkTank Change-Up and any of the Speed Demon, Freak, and Racer line.
If you already know where I'm heading with this, then you can skim through this but I think this is essential. After lengthy discussions with ThinkTank and a barrage of questions, I took home the following.
  • A ThinkTank Change-Up was designed as a lens carrier. Similar to the Lens Changers, however, this actually wraps around your body and confined to one case.
  • A ThinkTank Change-Up can fit a body but don't expect it to be a prime Camera pouch. Just because you can fit other things in it, doesn't mean you can put anything in it. (For the most part, that statement holds true but for the purpose of using it as a camera pouch, it will defeat the purpose).
  • You can essentially "change-up" any of the Speed lines (Demon, Freak, and Racer). I will go into this in more detail.
  • I'll throw this out there, the Speed lines can accommodate the cameras comfortably.
    Demon (Camera without Grip)
    Freak (Camera without Grip, a little larger)
    Speed (Camera with Grip, Pro Cameras - Mark series, 40D w/grip, etc. and room for lenses or two bodies with grip, depends on which body but no room for anything else)
With the information above, make sure you keep those in mind. That should de-mystify many of the misconceptions that people will give you. I don't know how many times I have asked the question whether the Speed Racer can fit two bodies and people would actually persuade me to look at the Change-up. Huh?? Completely two different things!
Quality
There is no doubt that this item is made with high standards. You get what you paid for and in my opinion was well worth it! There are LowePro versions, Tamrac versions but I feel that the ThinkTank was well built and the engineers actually took every piece and ensured that it was designed properly.
The construction is rigid and I know that some of you may like the Domke flexible feel but this is definitely different in that regards. Yes, it will look like a camera bag. Other than that, I saw no flaws in the quality that this was made.
Design and Features
Now the fun stuff! I should begin by saying that it comes with a couple of goodies (it better for the price I paid for ~160)
  • A pixel pocket rocket (essentially a business card holder and memory card holder)
  • Accelerator Shoulder Pad
  • Seam Sealed Rain Cover
Apart from these, it comes with several partitions and spacers that can be removed or attached to fit whatever configurations you want.
The nylon material that the bag is made out of is very durable and rest assured, the quality is top-notch! It has a rigid structure so if you are looking for something that has a Domke flex, then this isn't for you! It does look like a camera bag but it's suttle enough to not scream out that it's one.
There are several pockets throughout the bag (which I won't get into detail) but enough to store your little essentials. Formidably, enough to not worry about.
Canon EOS 40D | EOS Rebel XTI/400D | G9
Lenses and Gear List
Review of my ThinkTank Gear
nutsnbolts
Oct 04, 2007 11:23 |  #2
Other cool features is the removeable insert inside the speed racer which I can see can come in handy (don't know for what yet) but yes you can remove it. I'm not talking about partitions but the padding that surrounds it. In addition, enclosed inside (in a small pocket) is the rain cover.
nutsnbolts
Oct 04, 2007 11:24 |  #3
Lastly, what I love about this is the waist belt which can be tucked into a pocket. Some reviews I have read said that it can bulge the speed racer but I didn't see that happening. Like the Change-Up, you can use it as a shoulder bag without the waist belt dangling around. To support the belt, the Accelerator shoulder pad (external link) can be attached (which is used as well if you want to use it as a shoulder bag) and strapped across your chest. Essentially, it's called Accelerator (external link) because you don't need to slip it off over your shoulder but slide the pack forward from the back and bam, you're ready to shoot!
Is it a good to shoot out of.... bag?
Definately! The way the camera sits inside, the way the bag opens, it makes lens changes easy and taking the camera in and out of the bag is a cinch.
What about the waist belt?
Let's put it this way, go to the ThinkTank products page on their website and you can see all the things that you can attach to it to expand what you can carry. Personally, I have the Chimp Cage (external link), Digital Holster 50, and Lenschanger 75 and 50. Take note that due to the size of the belt, only two items can be attached (1 on each side). I have seen the Chimp Cage (external link) attached to the actual Speed Racer bag which leaves room for 2 items on the belt. That's how versatile it is. The last thing to note is their "patent pending" slip lock mechanism. Essentially, with the items on your belt, the locking mechanism will prevent things from slipping back and forth.
Summary
Overall, I was very pleased with my purchase. I still think I will purchase a Domke F-1x and a Crumpler 7MDH in the future due to it's "quiet" (shh it's not really a camera bag) looks but this bag is great as a walk around bag and to carry your gear in general. Some of the reviews that you may read may say also that the Speed Racer is quite large in comparison to the other two (Freak and Demon). But if you want to have your grip on the camera, the only choice you have is the Racer. You can "force fit" the camera into a Freak but why do that? The size isn't all that large (like I said it's all subjective).
It's packed with features, it's expandable, and also great to note, I have bought the Shoulder Harness which I can attach to it and convert it into a backpack!
Picture Provided by ThinkTank
Lastly, hopefully you can find some use with this review because I know I racked my brains trying to find reviews for this. Notably, there are two reviews @ Cambags.com which you can check out as well.
If you're interested, there are other reviews here that I did (just search for it).
Docsknotinn
Oct 04, 2007 15:52 |  #4
Is there any way you can tell how big the waist belt is?
nutsnbolts
Oct 04, 2007 16:06 |  #5
It's roughly about 8 inches in height. I should have mentioned that as well. The design for it being that big is to provide coverage and support if you want to strictly use it as a waist bag. Due to the weight that the bag portion may carry, imagine if you had a skimpy belt around you, it would choke your waist. Here the 8 inches actually spreads out to support the weight.
If you are concerned about it being huge, honestly, it's not. You won't even notice it.
MDJAK
Oct 04, 2007 18:57 |  #6
I own this bag and agree with many of the things you've stated in your excellent review.
May I just add a few comments:
1. This bag becomes very tiring (at least to me) on the waist. It's a large bag, holds a lot and is obviously heavy. Even with the shoulder strap supporting some of the weight, I cannot comfortably carry it for long periods of time.
2. I've never seen the backpack support. Interesting, but I'd rather own a backpack if I were going to use it that way.
3. The zipper on the top compartment, while a nice touch, seems useless to me as you really can't slip anything in or out of it.
4. The draw string pouches on the side are too small for a flash and not very practical in a drizzle as they are open to the elements.
There is no doubt it is a high quality bag, but mine has sat in my closet unused for over a year now.
There's also no question they are priced quite high.
mark
nutsnbolts
Oct 04, 2007 19:08 |  #7
MDJAK wrote in post #4065603 (external link)
Yeah, any bag really gets tiring even the backpacks. It comes down to how fit you are and then the design on the pack. I find this pack though to be ok with weight distribution. Ok, in terms of, they give enough options to try and alleviate the weight in different ways.
Of course, don't overpack as well is another thing to keep in mind. Lastly, I have the Vertex 200. As comfortable as that pack is, it gets to be a burden after a few hours.
We all don't have one pack that we live by...lol. At least I don't.
I agree with this, I didn't really mention it because it's not like you can pull a camera through it. When I first got this, I wondered as well what this was about. Hmm...if you're on the run and need to stick in something, I guess..
Yeah, I would put other things in there.
mark
Well, I think the price is decent. In comparison to other bags out there. I rate the price in whether it can accomodate two bodies or not, upon which, the bags that can carry two bodies are the following:
  • Crumpler Brazillion Dollar Home - $280 USD.
  • Domke F-1x - $150 USD or so.
It's roughly competitive.
SunTsu
Oct 07, 2007 01:13 |  #8
Did you also consider a Billingham? For some reason, they don't seem too popular. I'm not sure if it's because they are rather pricey.
Canon 5D Mark II+BG-E6, Canon 5D+BG-E4 | 200-400mmL IS, 85mm F1.2L II, TS-E 17mm F4.0L , 16-35mm F2.8L II, 24-105mmL IS, 70-200mm [COLOR=#000000]F2.8L II IS, 100mm F2.8L Macro IS, 100mm F2.8 Macro, 40mm F2.8, 1.4x II, 2.0x III | EF12+25 II | Canon 600EX-RT (x5) | Gitzo support
Full Gear List
nutsnbolts
Oct 07, 2007 08:18 |  #9
Price is definately over the top for a Billingham. They are great quality and supposedly a great bag as well but Domke is more of a rival of it and a lot less expensive.
olz
Nov 08, 2007 02:56 |  #10
The zipper in the top is like the Lowepro Stealth series. It actually quite usefull from their 500AW and up. Large enough to get your camera through, if it's placed in the middle of the bag. As you point out above I don't see the use of it in smaller bags. Only if you wear your camera ready to shoot all the time, and use the bag to hold lenses only.
Cheers
Kristian @ www.kindanatural.com (external link)
Fuji X-Pro1 | Fujinon XF18mmF2 R | Fujinon XF35mmF1.4 R
nutsnbolts
Nov 08, 2007 08:23 |  #11
olz wrote in post #4275880 (external link)
Just to clarify, the zipper above can possibly fit a camera with no grip through the zipper. Yes, it's probably possible as well with the grip but you'll really need to play with it. It's far much easier to unzip the top (around the bag) than the one zipper down the middle to place the camera back.
The wonderful thing about the Speed Racer is really the fact that it can be in shooting position by just spinning the bag around to the front. So technically it's a bag that ready to shoot 24hrs a day so to speak. In addition, the Speed "series" (Racer, Freak, Demon) are all moderate sized bags with Racer being the largest.
If you really want to go smaller, there is the ever popular change-up which was designed as a lenschanger/holder/car​rier. Although you can put in a dslr in it (tight fit) but I have seen it used that way.
Triptoph
Location: Glasgow, Scotland, UK & Vancouver, BC, Canada
Dec 05, 2007 15:57 |  #12
I'm looking for something to hold a 30D attached to a 100-400mm that can be carried in front of me or to the side while walking through crowded areas in 3rd world countries, and the ability to put it behind you would be a bonus. Also Need a place for a 17-55mm, and need the ability to swap between the two lenses. Taking a close look at the Speed Freak. I do not use the grip on my 30D.
Do you think the 30D+100-400mm attached would fit in the racer? With a detached 17-55mm as well?
It looks like a very good system, thanks for the review!
-Tony
nutsnbolts
Dec 05, 2007 16:17 |  #13
Triptoph wrote in post #4446702 (external link)
Yes it will. The speed racer is the largest between the 3 of them and it will definately fit additional lens.
Triptoph
Dec 05, 2007 18:08 |  #14
Oh sorry, I meant to ask about the Speed freak. I'm getting my speeds mixed up :) I'd rather have a slightly smaller pack if it will fit the 30D + 100-400mm attached and 17-55mm alongside.
-Tony
nutsnbolts
Dec 05, 2007 18:34 |  #15
It will be a tight fit. Cutting it close.
32,930 views & 0 likes for this thread, 10 members have posted to it.
Latest registered member is SwampWombat
2223 guests, 196 members online
