Strick wrote in post #4069501
I have two questions I have been wondering about.
1) Do you shoot with one eye or both open? I have always shot with with the "unused eye" closed but sometimes that cause problems for me if I am shooting for an extended period. It is just one of those things I have always wondered about.
Whatever's most comfortable for you really. You'll find that one of your eyes (most likely your right one) is the "master" eye, so when you look through the viewfinder with that eye, your brain understands what you're doing (and you won't suffer from parallax issues). You'll find that you naturally either keep the other eye open or close it.
2) This is more technical question......What, if any, advantage is there in using all the AF points on instead of just the center? I have always used the center but wonder if I a missing something.
There's differing schools of thought here. Many people will get away with only using the centre focus point, but the detriment there is that the subject of focus is dead centre. Doing that is fine, but it can lead to composition problems.
In the "any AF point" mode, you can have issues where the camera will chose the closest best candidate (basically an area of high contrast/edge) on which to focus. This can potentially lead to problems where you'll uninentionally focus on something other than what you want to focus on (i.e something in the foreground or background).
An alternative is to get yourself used to selecting the AF point yourself when you take the shot. Thinking about the AF point will also help you to focus on the composition, and can give you a better shot than simply using the centre AF point and snapping at things.
