Thread started 05 Oct 2007 (Friday) 17:55
Using C.Fn-04 on Mark IIN - Action
WAF
Oct 05, 2007 17:55 |  #1
When shooting action, such as football, I have gone to C.Fn-04 to allow the press of the " * " to do my focusing when pressed and stop focusing when released. I am not sure whether to use setting 1 or setting 3 in this. Do you action photographers find greater success in getting in-focus shots using the "*" button method or setting it to "0" and allowing the shutter release button pressed half-way do the job for you along with AI Servo?
What setting do you use in C.Fn-20 for AI Servo tracking sensitivity for action sports such as football or basketball?
Adrian ~ Canon 30D, Canon Mark3, Canon 5D MarkII, Canon 5D MarkIII, Canon 7D, Canon:70-200mm/f2.8, 85mm/1.2, 50mm/1.4, Canon 14mm Fisheye, Canon 16-35mm f2.8L, Canon 24-70mm f/2.8, USM, 1.4X, 2.0X , Quantum T5d-R flashes.http://www.adrianfreem​an.com (external link)
Tapeman
Sliced Bread
Joined Jan 2004
Oct 05, 2007 18:14 |  #2
I use CF - 4-1 all the time except when I give the camera to someone else to shoot.
Canon G1X II, 1D MKIV, 5DSR, 5DIV, 5D MKII, 16-35/2.8L II, 24-70/2.8L II, 70-200/2.8L IS II, IS, 100-400/4.5-5.6 L IS II, 500/4 L IS II, 24-105/4 IS, 50/2.5 macro, 1.4x MKII, 1.4X MKIII, 2X MKIII,580EX II, 550EXs(2), ST-E2.
Gitzo 1228, 1275, 1558, Lensbaby 3G. Epson 3880, Bags that match my shoes.:)
gromeo
Oct 05, 2007 18:19 |  #3
Adrian
I use setting 3, I did find it easier, you can focus on your subject, let go and you did not have to worry about loosing focus if subject moved or a subject ran in between. I shot 98% on manual so I don't use the setting that uses back button to focus and shutter to lock exposer. As far as C.Fn-20 I use I think it is 0 which is standard speed. If you go to this link, I pretty much have it setup with this
http://www.siphoto.com​/?canon1DM2N.inc (external link)
Hope this helps
Nikon D4 and 60 2.8D Micro, 24-70 2.8G, 70-200 2.8G VRII, 200-400 VRII, SB800, SB600, Pocket Wizards, 4x WL-1600, Quantum Turbo 2x2, Sekonic 358 meter, TT AS, Takeoff, Belt System
http://rguzmanphoto.ph​otoshelter.com/ (external link)
http://www.romeoguzman​photography.com (external link)
http://www.sportsshoot​er.com/rguzman (external link)
1,157 views & 0 likes for this thread, 3 members have posted to it.
1502 guests, 130 members online
