JohnAng wrote in post #4073911
I have been thinking of converting a spare room in the house into a studio for portrait work and was thinking of purchasing 3 lenses
50mm 1.4
85mm 1.8
135L 2
i already have the 24-70L 2.8 and the 70-200L 2.8 IS and was wondering will getting the primes give me better results then the lenses i already have.
When doing portraits in the studio, you will want to have the subject at least six feet or so in front of the background. You will also want the camera at least six feet or so in front of the subject. You will find that (using and APS-C camera) the 50mm focal length would normally work pretty well for "conventional" portraits with these distances. If you stretched to the 85mm focal length you would be limited to a head-n-shoulders framing at these distances. If you had a much bigger studio than the average "spare room", you might be able to use the longer focal lengths.
Keeping the distances between subject/background and camera/subject are very important. The subject/background distance will allow you to blur the background a bit so it's not so "busy" in the image. The camera/subject distance is even more important to get good perspective (relationship of foreground/background subject element sizes - consider noses vs. ears, etc.) in your images that will please the subjects.
I would suggest that you mock up the studio space before going full bore and see what focal length(s) work for you. There are many things that can be done to make a smaller space work for you as a studio. If you run into space problems, bring that up here and you will get a lot of ideas to work with.
