Thread started 06 Oct 2007 (Saturday) 11:16
Artifacts removal
sagebrush
Joined Dec 2001
Oct 06, 2007 11:16 |  #1
I can't seem to remove these artifacts (if that's indeed what they are) in the sky and mountain without distroying details in the water. This is crop from a RAW shot using a 20D processed in C1 saved as a TIF with on sharpening, cropped using CS2 and saved again in TIF. They aren't boxey like compression artifacts so what are those little squiggle lines and how do I get rid of them? If anyone wants to try their hand at getting ride the artifacts while saving the details in the water and leaves please give it a try.
Sam442
Oct 06, 2007 12:04 |  #2
The lines on the land are noise mixed with oof detail,
two very quick versions, one is just the clone tool, other is magic wand + gaussian blur.
sharpening a bit less would help. :)
<edit> 2nd one is the blur one, just noticed how terrible it looks, so ignore that :D
"...With 127,000+ members, no matter what you do,
some will love it, someone will hate it, & some should go out & spend more time shooting & less time talking about it? ;)"
- PhotosGuy
bckane
Oct 06, 2007 12:46 |  #3
Ok I will take a shot at it
Before
After
Brian
Canon 7D-40D gripped | EF 24-105mmL | EF 100mm | EF 28-135mm | EF 70-200 F/4L | EF 135 F/2L | Sigma 17-70mm | EF 50mm 1.8 | Tokina 11-16mm | Speedlite 430EX
| Bogen 3265 | Manfrotto 055xprob and Manfrotto 488RC2 | Katz Eye Optics | Sigma 70-200mm F2.8 EX DG | ZERO Balance check book |
Swift
Oct 06, 2007 14:12 |  #4
IMAGE: http://i22.tinypic.com/34j3l81.jpg
My try...
Canon 550D | Canon 70-200mm f/4L USM | Canon 17-55mm f/2.8 IS USM | Canon Speedlight 430EX | Raynox DCR-250 Macro
sagebrush
Joined Dec 2001
Oct 06, 2007 15:37 as a reply to  @ Swift's post |  #5
Many thanks to all of you..they are all improvements over my original.
If I had to pick just one I would go with bckane's after version. Would explain the steps you used to get your results?
Thanks again.
sagebrush
Joined Dec 2001
Oct 06, 2007 15:40 |  #6
Sam442 wrote in post #4075987 (external link)
What is off detail? And how is it created?
bckane
Oct 06, 2007 16:58 |  #7
sagebrush wrote in post #4076821 (external link)
Thanks again.
Glad you liked the after version, steps I took were
1....Selected the sky and mountions with the Quick Selection tool in CS3.
2....Then used reduce noise (strength 10%) Remove JPEG Artifact
3.....About 75% USM
I think thats about it....pretty easy touchup to remove noise
Brian....
Brian
sagebrush
Joined Dec 2001
Oct 06, 2007 18:05 as a reply to  @ bckane's post |  #8
I don't use CS2 very often... I can select the sky+ground then copy it into a new layer then reduce noise but what is the Quick Select tool..than sound faster and simpler.
bckane
Oct 06, 2007 18:32 |  #9
sagebrush wrote in post #4077440 (external link)
Its like the magic wand....
Brian
sagebrush
Joined Dec 2001
Oct 06, 2007 18:57 as a reply to  @ bckane's post |  #10
Too cool!...thanks
bckane
Oct 06, 2007 19:41 |  #11
sagebrush wrote in post #4077657 (external link)
Too cool!...thanks
Here ya go this might help
http://livedocs.adobe.​com …ec-81F3-CF04EE5295FC.html (external link)
Brian
1,892 views & 0 likes for this thread, 4 members have posted to it.
Artifacts removal
1210 guests, 131 members online
