Thread started 06 Oct 2007 (Saturday) 13:11
RULE OF THUMB HANDHELD SHUTTER SPEED?
zucchini
Oct 06, 2007 13:11 |  #1
As a rule of thumb, what is the lowest shutter speed one can use without image stabilization? Some people have better abilities than others so I would expect the speed to vary. That said, I am looking for what an advanced amateur should be using.
Thank you,
zucchini
A Camera ~ A Lens ~ A Flash ~ A Tripod
http://www.zandecki.ne​t (external link)
liza
Oct 06, 2007 13:15 |  #2
How long is your lens? I usually observe the 1/focal length rule.
Elizabeth
Blog
http://www.emc2foto.bl​ogspot.com/ (external link)
number ­ six
fully entitled to be jealous
Oct 06, 2007 13:19 |  #3
For 35mm cameras the rule of thumb was always 1/focal length for shutter speed, as Elizabeth says.
For crop cameras, like most of our DSLRs, it's 1/(fl * crop factor).
That is, if you're using a 200mm lens, 1/320 is the minimum.
BTW, it takes a while to learn how to take a shake-free picture at this figure...
-js
"Be seeing you."
50D - 17-55 f/2.8 IS - 18-55 IS - 28-105 II USM - 60 f/2.8 macro - 70-200 f/4 L - Sigma flash
zucchini
Oct 06, 2007 13:21 |  #4
I have not heard of that rule. It sounds very easy to follow!
My lenses are listed below in my signature.
Thank you,
zucchini
crn3371
Oct 06, 2007 13:23 |  #5
The old rule of thumb has always been 1/focal length. With the advent of digital, and cropped bodies, it now seems to be 1/focal length x crop factor. So, for example, at 300mm the old rule would be 1/300 sec. With your XTi, the crop factor gives you the field of view of a 480mm lens, so 1/480 sec. These are rough guidelines only. The longer the lens, the more I'd err on the side of speed.
JackProton
Oct 06, 2007 15:21 |  #6
crn3371 wrote in post #4076285 (external link)
Yeah. I can usually get away with even slower shutter speeds wth wide-angle focal lengths.
tsaraleksi
Oct 06, 2007 15:24 |  #7
If you practice you can usually manage a bit slower than 1/length, at least in my experience. I can usually manage 1/125- 1/160th or so with a 70-200, I think most probably could with some work.
--Alex Editorial Portfolio (external link)
|| Elan 7ne+BG ||5D mk. II ||1D mk. II N || EF 17-40 F4L ||EF 24-70 F2.8L||EF 35 1.4L || EF 85 1.2L ||EF 70-200 2.8L|| EF 300 4L IS[on loan]| |Speedlite 580EX || Nikon Coolscan IV ED||
kitacanon
Oct 06, 2007 18:10 |  #8
I won't use lower than 1000/sec with my 300mm Nikkor...
My Canon kit 450D/s90; Canon lenses 18-55 IS, 70-210/3.5-4.5....Nikon kit: D610; 28-105/3.5-4.5, 75-300/4.5-5.6 AF, 50/1.8D Nikkors, Tamron 80-210; MF Nikkors: 50/2K, 50/1.4 AI-S, 50/1.8 SeriesE, 60/2.8 Micro Nikkor (AF locked), 85mm/1.8K-AI, 105/2.5 AIS/P.C, 135/2.8K/Q.C, 180/2.8 ED, 200/4Q/AIS, 300/4.5H-AI, ++ Tamron 70-210/3.8-4, Vivitar/Kiron 28/2, ser.1 70-210/3.5, ser.1 28-90; Vivitar/Komine and Samyang 28/2.8; 35mm Nikon F/FM/FE2, Rebel 2K...HTC RE UWA camera
JohnJ80
Oct 06, 2007 22:12 |  #9
number six wrote in post #4076271 (external link)
-js
And that is the BARE MINIMUM. You really should plan on 2-3X faster to gain good sharpness.
J.
Obsessive Gear List
"It isn't what you don't know that gets you in trouble; it's what you know for sure that isn't so." - Mark Twain
ANGUS
Oct 07, 2007 04:56 |  #10
I can hand hold 300mm at f5.6 taking a shot of a slow moving car with IS at 1/60th at ISO100.
Angus
| 1D MkIV | 1D MkIII | 5D MkII | 15FE | 16-35 f2.8 L | 24-70 f2.8 L | 70-200 f2.8 IS L II | 35 f1.4 L | 135 f2 L | 300 f2.8 IS L | 580 EX II | 580 EX II |
tmonatr
Oct 07, 2007 05:46 |  #11
NSWESP wrote in post #4079810 (external link)
zucchini wrote in post #4076240 (external link)
Reading is good.;)
Tim
Bartender - "So, you guys are dictionary salesmen."
Roy Munson - "You would be punctilious in assuming that."
ANGUS
Oct 07, 2007 05:55 |  #12
I saw that, I was simply stating what IS can acheive.
Angus
lcpete
Oct 07, 2007 10:28 |  #13
Good thread I did not realise that you had to multiply by the 1.6 cropfactor
I have found though that a speed of 160/ 200 will consistently give sharp shots with a 105 macro. In good conditions holding the camera steady and using burst I can get good shots at 60.
Pete
Canon 40D, 350D, 550D and 7D :D
Sigma 105, 150 and Canon 100L Macro
Canon 70 - 200 F4L,
Canon 100 - 400L, the wifes but I borrow it !
Floriantrojer.com
Oct 07, 2007 10:36 as a reply to  @ lcpete's post |  #14
Without IS I'd say 1/160th at 400mm.
With IS on I'm getting keepers with 1/30th also, but ratio is rather low of course. Maybe 5 out of 30.
www.floriantrojer.com (external link)
Canon 1Dmk3, 20D + Lenses
sfaust
Oct 07, 2007 10:51 |  #15
I don't understand why you would need to increase the shutter speed for a crop camera. The physical focal length of the lens is the same if you use a full frame or a smaller sensor. The difference is that the sensor is smaller and thus only capturing a smaller portion of the same area that a full frame would.
It doesn't change the physics of motion/focal length at play, so the camera/lens motion would be the same on a full frame and a cropped camera. So the same 1//focal length should apply. The actual physical focal length hasn't changed at all between FF and crop.
Am I missing something?
Stephen
Mix of digital still gear, Medium format to M4/3.
Canon EOS Cinema for video.
Commercial Photography (external link)
5,143 views & 0 likes for this thread, 17 members have posted to it and it is followed by 2 members.
2801 guests, 162 members online
