If it doesn't show on the image, I'd try and forget about it. But being neurological as I am, I would find it hard.
You could complain to the seller, I suppose, but if it doesn't affect your images, then forget about it.
Keep in mind, if you see something on your sensor, it will likely affect the opposite size on your image - the image on the projected image circle from a lens is inverted (ie if there is dust at the top of your sensor, that is the bottom of your image - can't remember if it inverts left to right as well, but seeing as a lens has no idea about orientation, I'm guessing it does too) - so it's possible it does affect your image, but you're not looking in the right place.
