Thread started 06 Oct 2007 (Saturday) 17:16
Action Shots???...TV mode???
mike397
Oct 06, 2007 17:16 |  #1
I set the 40D in the basic/sports mode ...the images seem ok and this setting seems to follow any movement with clarity.
I then seet the camera to creative zone/tv mode,one shot/high speed drive...the moving objects are all sharp but the overall exposure seems to be a little darker.
What am I doing wrong?...shouldn't the exposure match the ones in the sports mode?
I'm new to this camera {1 week old} and I've never used the tv mode ,as I do mostly landscapes and portraits.
Any help would be appreciated
Thanks ,
mike
Canon 24-105L ,,Voigtlander 40mm & Apo Lanthar 90mm macro...,Nikon 55mm f2.8 micro ,Leica 60mm f2.8 macro ,Leica 180mm f4, Zeiss c/y 135mm f2.8 ,Olympus 21mm f3.5
http://mike397x.zenfol​io.com/ (external link)
Emberghost
Oct 06, 2007 17:43 |  #2
Compare the exif data for yourself between shots of different settings. You should see what changes and what doesn't.
When I shoot sports this is what works for me...
AV mode @ lowest fstop ( 2.8 )
Depending on how much light is out I use ISO 100-400 (higher if needed)
AI servo focus w/center AF point
Burst shot <--- forget the technical term
So basically I keep my aperture the same, and get the shutter speed I want by playing with ISO.
If I notice players are in something dark and it's very bright out and everyone is getting underexposed I'll play with exposure compensation and set it +1 or so.
Hope this help, -Adam
Just did it this way this morning with these shots -> http://atphotography.s​mugmug.com/gallery/360​0263#204739942 (external link)
20d | 7D | sigma 18-50 f2.8 macro | 50 f1.4 | 70-200 f2.8L
My Website (external link)
Myles7
Oct 06, 2007 17:51 |  #3
Well, this hasn't anything to do with exposure - but you don't want to be (in general) in one-shot mode for any kind of sports - get it into one of the servo AF modes.
:D 1D Mk III:D 5D mk2 - mk1 just sold:confused:
SiggyFish 15mm, Siggy 12-24, Canon 24 3.5 TS-E L, 16-35 2.8 mk II L,45 2.8 TS-E, 135 2.0 L, 70-200 2.8 IS L , 300 2.8 IS L, 580EX2/430EX, EF2x/1.4x TC mkII, 50 1.8
mike397
Oct 06, 2007 18:50 as a reply to  @ Myles7's post |  #4
Emberghost,Miles7,
Thanks for your reply's.
Yes,I think the problem was I was in one shot mode....
Emberghost-great shots,razor sharp...were you using the 70-200F2.8 L..?
Mike
Emberghost
Oct 06, 2007 19:03 |  #5
mike397 wrote in post #4077629 (external link)
Emberghost,Miles7,
Mike
Thank you, that I was. Here are a few other examples I posted up here a while ago of college football all done the same way as well. Best of luck, hopefully you get the hang of it.
https://photography-on-the.net/forum/showthre​ad.php?t=382242
dave ­ kadolph
"Fix the cigarette lighter"
Location: West Michigan--166.33 miles to the Cook County courthouse
Oct 06, 2007 20:25 as a reply to  @ Emberghost's post |  #6
You may have to experiment with metering modes also.
My home team wears reflective black and white uniforms which drive a spot meter crazy.
And Emberghost has given you very good advice:D
Middle age is when you can finally afford the things that a young man could truly enjoy.
Tools of the trade
packpe89
Oct 06, 2007 21:04 |  #7
My guess is you metering is different. What were you shooting in the Tv mode? I am not sure what the sports mode uses, but I ussually center weighted, when shooting Av, mode (don't use Tv much). I am findning, that for sports however, Manual works really good, as long as the lighting is constant, otherwise your exposure will srew up, if one shot is metered on a white jersey and the next on someone's face.
When I shoot manual, I put the camera's spot meter on and keep focussing inthe players face with a half-shutter, this will tell you on the exposure guage, if you are metered correctly.
Joe
Canon 5D, 7D, 100-300F4, 200f2.8L, 17-40L, 50f1.4, 85f1.8, 15-85EF-S , Sigma 24-70f2.8, A couple of flashes, strobes and stuff.
timbop
Oct 07, 2007 10:46 |  #8
A lot depends on whether you are talking day or night. During bright daylight I will go ISO 400, Av, f/4, evaluative, AI servo, and continuous. Once twilight hits I start to up the ISO and keep an eye on shutter speed, keeping it at 1/400 or better. Once the lights are the primary light source, I switch to ISO 'H' (3200), Tv mode, 1/320 or 1/250, center weighted metering. I prefer to get an underexposed shot than a motion blurred shot. I find that often f/2.8 is good enough most of the time to expose within a stop.
Current: 5DM3, 6D, 8mm fish, 24-105/4IS, 35/2IS, 70-200/2.8IS, 85/1.8, 100-400/IS v1, lensbaby composer with edge 80, 580's and AB800's
Formerly: 80D, 7D, 300D, 5D, 5DM2, 20D, 50D, 1DM2, 17-55IS, 24-70/2.8, 28-135IS, 40/2.8, 50/1.8, 50/1.4, 70-200/4IS, 70-300IS, 70-200/2.8, 100 macro, 400/5.6, tammy 17-50 and 28-75, sigma 50 macro & 100-300
WAF
Oct 07, 2007 17:18 as a reply to  @ Emberghost's post |  #9
Emberghost: Can you turn on your exif info on your smugmug web site for us to look at?
Adrian ~ Canon 30D, Canon Mark3, Canon 5D MarkII, Canon 5D MarkIII, Canon 7D, Canon:70-200mm/f2.8, 85mm/1.2, 50mm/1.4, Canon 14mm Fisheye, Canon 16-35mm f2.8L, Canon 24-70mm f/2.8, USM, 1.4X, 2.0X , Quantum T5d-R flashes.http://www.adrianfreem​an.com (external link)
1,569 views & 0 likes for this thread, 7 members have posted to it.
1375 guests, 181 members online
