Thread started 07 Oct 2007 (Sunday) 13:02
Stupid question about flash...
andy_fozzy
Oct 07, 2007 13:02 |  #1
Ok, I'm still pretty new to photography, and even newer to the 400D!
When using the flash, the shutter speed automatically reduces itself dramatically (Av mode) resulting of course, in major shake.
I can use a pretty fast shutter speed on Tv, and get a nice shot.
Can anyone explain why this is happening?
It didn't happen on my ex Nikon D40!!
My Gearhttps://photography-on-the.net/forum/showthre​ad.php?t=416926
elader
Joined Nov 2005
Oct 07, 2007 13:18 |  #2
Av mode when using a flash is very different than shooting without the flash. Basically it tries to set the exposure correctly **without considering the flash** and then uses the flash forr fill in. This is a great mode to use outdoors when someone's back is to the sun and their face is in shadow.
Try this - set the camera on manual, set the ISO400, set the lens wide open, set the SS at 1/160th and shoot with the flash up -
when shooting with an automatic speedlight, you can shoot on manual. If it's too dark, you have to drop the SS or raise the iso.
I made the same 'error' you did when I first got a canon dSLR.
Eric
FJR1300 rider
5D mkIII and 1D MkIII
16-35L | 24-105L | 70-200L f/2.8IS | 85 f/1.8 / 50 f.1,4
JeffreyG
Gallery: 42 photos
Oct 07, 2007 13:23 |  #3
In Av mode your camera will always set SS to the correct exposure without flash. In a dark scene this means the shutter speed may be very slow indeed. Av is a nice mode to use for fill flash in daylight. I'm not so keen on Av when flash is the main illumination or when dragging the shutter.
In Tv mode, the shutter speed is set by you and in a dim scene the camera will open the lens up as far as possible. Then when you enable flash the flash will fire and light the scene to the correct final exposure using E-TTL. This is an OK way to shoot flash, except the lens will always be wide open and you have little control over the DOF.
The best way to shoot flash is in manual mode. Pick the aperture you want for DOF, pick a shutter speed you can live with and let E-TTL meter the flash for proper exposure. Bounce flash can give excellent results this way.
Also in M, you may find you can run a slowish shutter (like 1/30) - especially with an IS lens since you can count on the flash to freeze motion to some degree.
I have no idea how the D40 works, although I would be really surprised to find the camera does not meter to ambient in Av mode.
René ­ Damkot
Oct 07, 2007 13:34 |  #4
Av mode on a Canon works similair to your D40 with slow sync enabled...
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
andy_fozzy
Oct 07, 2007 13:40 as a reply to  @ René Damkot's post |  #5
Thanks for the help guys - appreciate it.
Interesting stuff, and I'm sure I'll get used to it eventually!!
Thanks again
Doug ­ Pardee
Oct 07, 2007 17:26 |  #6
For more information on flash from the Digital Rebel FAQ, click here (external link).
xarqi
Oct 07, 2007 19:59 |  #7
There is a custom function, at least on the 30D there is, that allows you to specify that 1/250 s always be used in Av mode with flash. I use this where I want to use flash to isolate the subject by underexposing the background. The converse, which is the default, is as the others have described, and allows fill-in flash with correct exposure of the background.
Cathpah
Oct 07, 2007 21:01 |  #8
andy_fozzy wrote in post #4081746 (external link)
Thanks again
don't get intimidated....just keep on trying and learning from the changes you make instantly (isn't digital great?!)
you'll wrap your head around it, and eventually wonder how you were ever confused by it.
keep on pluggin away!
Architecture (external link) | Fashion + Beauty (external link) | Travel (external link) | Mayhem (external link) | Instagram (external link)
tools of the trade
My name is Jeff, and I'm addicted to shadows in fashion and brights in architecture. "Hiiiiii Jeff."
andy_fozzy
Oct 08, 2007 15:33 |  #9
xarqi wrote in post #4083778 (external link)
Ah, I've seen that settings in the menu.
I'll give it a try ;)
Thanks allot.
andy_fozzy
Oct 08, 2007 15:34 |  #10
Cathpah wrote in post #4084099 (external link)
Thanks Cathpah.
You're right, that's the beauty of digital!
Pretty much the reason I never got into film photog.
Cheers :cool:
andy_fozzy
Oct 08, 2007 15:35 as a reply to  @ andy_fozzy's post |  #11
Huge THANKS to everyone for the replies.
Lots of good help and advice, and I'll post my results!
Thanks again, Andy
burge
Oct 08, 2007 15:38 |  #12
There is a custom function, at least on the 30D there is, that allows you to specify that 1/250 s always be used in Av mode with flash..
1/200s with the 400D
Body: Canon 70D. Glass: Canon 70-200mm f4 L , Canon 50mm f1.8, Tamron 17-50mm f2.8. Sigma 10-20mm Flash: Canon 580exII, Canon 430ex, Yonguo 565. Accessories: Pocket Wizard Mini TT1 and Flex TT, Lee 100mm Filter holder, Hitech Pro Stopper.
andy_fozzy
Oct 12, 2007 03:57 |  #13
burge wrote in post #4088865 (external link)
Tried this option yesterday, and is working well for me.
kcbrown
Oct 12, 2007 04:39 |  #14
JeffreyG wrote in post #4081651 (external link)
Question about this: do you find you get better results using first curtain sync or with second curtain sync? I'd think that second curtain sync would be preferable in general when using a relatively slow shutter speed but that's not based on any real experience...
"There are some things that money can't buy, but they aren't Ls and aren't worth having" -- Shooter-boy
Canon: 2 x 7D, Sigma 17-50 f/2.8 OS, 55-250 IS, Sigma 8-16, 24-105L, Sigma 50/1.4, other assorted primes, and a 430EX.
Nikon: D750, D600, 24-85 VR, 50 f/1.8G, 85 f/1.8G, Tamron 24-70 VC, Tamron 70-300 VC.
Collin85
Oct 12, 2007 04:46 |  #15
Andy,
It's because under Canon's system, Av resorts to 'fill flash' mode. Often people just assume that flash means 'fast shutter speed', but that's not always the case. With Av mode, the flash by default will try to just 'fill in' some extra light to make sure your foreground subjects are properly exposed. It will still however expose to ensure the background is also decently exposed. For this reason, you'll notice that the shutter speed doesn't actually differ compared to Av mode without using flash.
So just to recap, because Av mode's default flash paradigm is 'fill-flash', that means it cannot just raise the shutter speed like you want. Because if it did, the background may become poorly exposed, hence defeating the purpose of the mode being fill flash only. If you didn't care for fill flash, and just wanted the foreground subjects to be decently exposed (with fast shutter speeds in poor lighting), then use Tv like you have been or use Manual. Or, like already mentioned, there's a C.Fn available to force the shutter speed to over 1/200th second under Av mode. In other words, effectively disable it's fill-flash predisposition.
Col | Flickr (external link)
Sony A7 + Leica 50 Lux ASPH, Oly E-M5 + 12/2
Canon 5D3, 16-35L, 50L, 85L, 135L
2,642 views & 0 likes for this thread, 10 members have posted to it and it is followed by 2 members.
2666 guests, 154 members online
