Thread started 07 Oct 2007 (Sunday) 14:05
Shutter Speed Weirdness...
Steve ­ Parr
should have taken his own advice
Oct 07, 2007 14:05 |  #1
So this was weird:
I was shooting a band last night. ISO was at 1600, and I was shooting in Manual mode.
About halfway through the shoot, regardless of which way I turned the wheel to select a shutter speed, the speed went up. Left or right, it didn't matter. The shutter speed only increased.
I removed the batteries and reinstalled them. I removed the grip and reinstalled it. Neither worked. I removed the grip, replaced the batteries with fresh ones, and that seemed to fix the problem.
The weird thing, though, is that the original batteries had a lot of life left in them. When I put them on the charger, the light on the charger was green (charged) in a matter of minutes.
I was just wondering if anyone else has experienced this...
Steve
Canon Bodies, Canon Lenses, Sigma Lenses, Various "Stuff"...
OnStage Photography (external link)
cdifoto
Don't get pissy with me
Oct 07, 2007 14:12 |  #2
I had that happen once. I don't recall which body it was though. The really odd thing was it didn't even matter which dial I turned...
gjl711
Oct 07, 2007 14:34 |  #3
None of the controls actually change anything in the camera. All they do is provide a stimulus so that the processor can change the settings with the exception of zoom, focus, and maybe a few others. Anyway, software can at times get confused which could cause many funny things to happen. Removing the batteries and waiting a few minutes causes the processor to reset.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
Steve ­ Parr
Oct 07, 2007 15:29 |  #4
gjl711 wrote in post #4081997 (external link)
That was my thought, too. Given that the replacement of the batteries fixed it, I was also thinking that maybe the camera just doesn't play nice with batteries that have a lower than optimal charge...
Steve
dubtdi
Oct 07, 2007 15:31 |  #5
Ctrl-Alt-Del...
Funny...don't remember having these types of issues on the Pentax K1000
basroil
Oct 07, 2007 15:53 |  #6
next time, turn off the grip. sometimes the grip acts weird on any camera (X0d and XX0d cameras alike) and you can only change the top wheel to the right (left acts like right)
SkipD
Joined Dec 2002
Oct 07, 2007 16:05 |  #7
dubtdi wrote in post #4082295 (external link)
Ctrl-Alt-Del...
.... or on my Nikon F's :p.
Pulling only the main battery (or batteries if using a "grip") will not cause the processer to do a "three-fingered-salute" type of reset. You have to (at least on the 20D and its sisters) also pull out the disc-shaped memory battery as well.
After leaving both the main battery(ies) and the disc-shaped battery out for a couple of minutes, the processor will reset and all user-configurable settings will return to factory-original when putting the batteries back into the camera and turning it on.
Skip Douglas
adas
Joined Aug 2004
Oct 07, 2007 16:12 |  #8
The only weird thing my 20D does is freezing up (albeit very rare) that neither buttons would work anymore. Luckily, turning it off and then back on solves the problem.
But isn't the 20D a notoriously problematic camera? Too many firmware patches were done for it, that probably the code is a mess right now.
6D, 20D, G7X
Steve ­ Parr
Oct 07, 2007 16:19 |  #9
SkipD wrote in post #4082465 (external link)
Well, if that's true, then this isn't the issue with my 20D. I only removed the BP-511's...
Steve
SkipD
Joined Dec 2002
Oct 07, 2007 16:23 |  #10
adas wrote in post #4082521 (external link)
I have had one minor hangup with my 20D in all the time I have used it. Cycling power resolved that issue (which I can't even remember the details of).
I'd say that overall the 20D is a pretty solid camera, especially if it has the latest firmware loaded properly into it.
Skip Douglas
997 views & 0 likes for this thread, 7 members have posted to it.
2796 guests, 162 members online
