Thread started 07 Oct 2007 (Sunday) 16:17
How big is your burst with noise reduction on? 40D
Sauk
Oct 07, 2007 16:17 |  #1
With noise reduction on the longest I get burst wise is 9 images before it slows, with it off I went as high as 61 and just decided to stop because it could have kept going.
Jon
Joined Jun 2004
Oct 07, 2007 17:10 |  #2
JPEG or RAW? Remember also that Noise Reduction essentially takes a second, blank, exposure to establish the noise levels of your sensor. If you're shooting bursts, it needs to work with the raw sensor data, so it's saving more information in the buffer.
Jon
Cocker Spaniels
Sauk
Oct 07, 2007 17:23 as a reply to  @ Jon's post |  #3
I was shooting jpeg. I figured that just wanted to see if others were getting the same number. My CF card is x133
cdifoto
Don't get pissy with me
Oct 07, 2007 17:26 |  #4
I thought noise reduction was only for long exposures, having no effect on bursts due to faster shutter speeds being used & NR not being applied. Did they change that with the 40D?
Sauk
Oct 07, 2007 17:30 as a reply to  @ cdifoto's post |  #5
well they have two different noise reductions, high iso and long exposure.
cdifoto
Oct 07, 2007 17:31 |  #6
Oh ok thanks for that information. Needless to say I don't own the 40D so I had no idea.
fz_za
Oct 07, 2007 19:47 |  #7
AthleticsPhotog, I get about the same number as you do with ISO Noise Reduction on. I guess, as Jon says, it just takes longer to complete the noise reduction process immediately after your shot. Makes sense, then, that this feature is turned off by default on the 40D so you can enjoy the full 6.5fps for a good 60-odd images :)
40D, 17-55mm f/2.8 IS, Sigma 30mm f/1.4, 70-200mm f/2.8L IS, 500D Close-up Lens, Speedlite 430EX with Demb Flash Diffuser Pro
B+W UV Haze, B+W Circular Polarizer | Lowepro Computrekker AW
Lightroom 2
dmitrim
Gallery: 13 photos
Oct 07, 2007 20:27 |  #8
Haven't tried it yet, Is it better than Noise ninja?
Facebook (external link)
www.dmitrimarkine.com (external link)
Cathpah
Oct 07, 2007 20:58 |  #9
dmitrim wrote in post #4083931 (external link)
in camera noise reduction better than noise ninja? Not in a million years.
Architecture (external link) | Fashion + Beauty (external link) | Travel (external link) | Mayhem (external link) | Instagram (external link)
tools of the trade
My name is Jeff, and I'm addicted to shadows in fashion and brights in architecture. "Hiiiiii Jeff."
Sauk
Oct 07, 2007 21:09 as a reply to  @ Cathpah's post |  #10
You see some help using it, but to be honest a program on your cpu is always going to be better then your camera at reducing noise.
Jon
Joined Jun 2004
Oct 07, 2007 21:14 |  #11
It's not so much better or worse as different. It's able to work with the original Bayer-masked pixels, so should theoretically do better.
BTW, although it's billed as "long exposure", the NR on the 5D appears to kick in at around 1/30 sec. Some tests I did showed a noise" bump at 1/60.
Jon
Cocker Spaniels
dmitrim
Gallery: 13 photos
Oct 08, 2007 02:05 |  #12
Cathpah wrote in post #4084081 (external link)
I thought so. The question is,why is it really there. I mean, 40D is not marketed to complete newbies. It's more for pro/semi-pro photographers. Why would I use this feature over Noise Ninja or similar Noise reduction software??
Super-Nicko
Oct 08, 2007 02:28 |  #13
agreed dmitrim... i dont see much difference in the shot and if its that bad then your going to take it to NNinja anyways, and for its effect on your speed... i guess it doesnt hurt to have it there as an option though... and not everyone shoots fast all the time... although even when im shooting one shot (95% of the time) i do not enable in cam NR.
My gallery - just posted some of my top shots (external link)
1DmkIII / 5DMKII [50mm f1.4] [85mm f1.8] [100mm f2.8 MACRO] [17-40mm f/4L] [24-70mm f/2.8L USM] [24-105mm f/4L IS USM] [COLOR=black][COLOR=bl​ack][[COLOR=black]100-400mm f/4.5-f 5.6L IS USM] Canon 1.4xII - Speedlite 580EXII - EPSON P-5000 - Lowepro Bags - Manfrotto 682B Monopod & 055XproB Tripod - 488RC2
Hermeto
Oct 08, 2007 02:37 |  #14
dmitrim wrote in post #4085506 (external link)
In camera noise reduction is used when photographer, amateur or pro, doesn’t matter, shoots .JPGs and wants to skip in-computer image processing all together.
tzalman
Fatal attraction.
Oct 08, 2007 03:33 |  #15
BTW, as far as I can see the high ISO NR is applied only to jpgs. On RAWs I can't see any difference with it or without it.
Elie / אלי
2,098 views & 0 likes for this thread, 12 members have posted to it.
2801 guests, 162 members online
