Thread started 07 Oct 2007 (Sunday) 20:36
Noise and camera age
mmahoney
Oct 07, 2007 20:36 |  #1
Maybe a stupid question but is there any relationship between camera actuations and noise?
My 20D is currently about 60,000 clicks and the files are noiser (at any ISO) than they were when the camera was younger.
Any clues?
Thanks,
Mike
Newfoundland Wedding Photographer (external link)
cctsm
Oct 07, 2007 20:42 |  #2
Sensor noise is quite unrelated to the amount of actuations, but it may suffer some aging effects. But I do doubt they'd be overly noticeable, if at all.
Sure you haven't changed some noise reduction parameters in either your camera (JPEG output), or in the RAW processing software defaults?
Canon: EOS 50D, EOS 400D, EF 300mm f/4L IS USM, EF 50mm f/1.8 II, EF-S 18-55mm f/3.5-5.6 II, EF 1.4X Extender, Speedlite 430EX
Sigma: 10-20mm f/4-5.6, 55-200mm f/4-5.6 | Tamron: 17-50mm f/2.8 | Manfrotto: 055 XPROB tripod, 680B monopod, 804RC2 and 486RC2 heads
Kenko extension tubes, Sandisk Extreme III 2GB + 8 GB & Ultra II 4GB
mmahoney
Oct 07, 2007 21:42 |  #3
cctsm wrote in post #4084010 (external link)
Camera settings are the same as always and I use and older version of DPP and process my RAW the way I always do.
So still a mystery.
Thanks,
Mike
jra
Oct 07, 2007 22:06 |  #4
I don't know...I've never heard of a sensor putting out more noise as it ages. Are you sure about your conclusion? Remember that the ambient temp can have an effect on noise. Warmer shooting conditions at high ISO can and will produce more noise.
photoroebucks
Oct 07, 2007 22:25 as a reply to  @ jra's post |  #5
are you sure its not because youve seen all the new age cameras with less noise and now your really assessing your 20ds noise more?;););)
greg roebuck.com
1D3, 5D3, 70-200 2.8 is ii,16-35 2.8 ,24 1.4 ii ,50 1.2,85 1.2 ii,135 2.0, 300 2.8is, hasselblad stuff, Profoto stuff, some other stuff, I sure do like stuff
ed ­ rader
"I am not the final word"
Oct 07, 2007 22:50 as a reply to  @ photoroebucks's post |  #6
20d really isn't that old.
ed rader
5D4 x2, 16-35L F4 IS, 24-70L II, 70-200L F4 IS II, 100-400L II, 14L II, sigma 15 FE, sigma 28 f1.4 art, tc 1.4 III, 430exII, gitzo 3542L + markins Q20, gitzo GT 1545T + markins Q3T, gitzo GM4562
photoroebucks
Oct 07, 2007 22:53 as a reply to  @ ed rader's post |  #7
ask a stupid question get a stupid answer:D
greg roebuck.com
40d
Oct 07, 2007 22:56 |  #8
Are you using the same lens*?
*Disclaimer: Regardless of whether or not you are using the same lens I have no actual educated response to your situation but it may or may not be a factor worth considering...
Photowebby (external link) :: Take Time to Think (external link) :: Your New Designer (external link) :: Doodls (external link) :: Gear
"I have a photographic memory. Unfortunately, it only offers same-day service."
"A picture is worth a thousand words. Make sure they are well written." - me
dpastern
Oct 08, 2007 00:27 |  #9
I've long had a sneaking suspicion that my 1D and D60 were both getting noisier as they got older (as well as hot pixels getting worse). Canon was asked in some interview a fair while ago (I can't remember where), how long they could expect sensors to last, and they dodged the question, which made me nervous. Nothing would surprise me ;)
Dave
karusel
Joined Nov 2003
Oct 08, 2007 02:25 |  #10
mmahoney: oh come on, just admit that you're craving for the 40D, you just need a plausible story for your wife... :D
Seriously though, I don't think the actuations-noise connection is far from the truth, I would assume the sensor doesn't just die, period, but it's dying, deteriorating slowly. I've seen some interesting images that my friend's old HP850 has produced, and I'm sure that the sensor certainly has a lifespan, and it's surely not human life long.
5D and holy trinity of primes. Now the 90mm TS-E TS-E fly bit me. I hate these forums.
M24
Oct 08, 2007 02:54 as a reply to  @ karusel's post |  #11
I picked up my 350D in Sept. of '05 and have about 15K clicks with it. I dropped it once while being rushed into an elevator in Tokyo, broke the filter, but the camera still runs fine.
The images it produces now are as sharp as the lens that I use. In fact, and I rather hate to say it, but I think my 350D is sharper than my 40D with my 70-200 f/2.8L IS. Damn, I really hate to say that.
I don't think that sensors go soft with age. I do believe they can fail, much like any other chip, be it memory or other. Perhaps your body needs a very thorough cleaning, all contacts, all pins checked, etc?
Best of luck there.
Michael
40D kit is sold | G10 Love it!!! | 350D w/BG-E3 | EF-S 10-22 | 70-200 2.8L | Canon 1.4x II | Tammy 28-300 VC | B+W filters | Novoflex Magicball | 50D and 5D MKII on the way...
mmahoney
Oct 08, 2007 06:35 |  #12
Thanks for all replies and suggestions .. first the files are certainly noiser, and it's been noticed by both myself and others. So it's not my seeing newer bodies with better sensors with lower inherent noise.
Although I won't need much more prodding to get a 40D :-)
My lens lineup is basically the same with one exception so we can rule out lenses.
Temperature is a factor, and to a surprising extent .. I've shot hockey at 3200 and the files are cleaner than the same ISO at summer temps. But I'm comparing equal temperature files here.
I at first thought maybe it was my computer LCD screen and had basically been ignoring it. But yesterday I posted some recent wedding pics and someone asked me what was up with all the grain.
These are relatively low ISO files .. 200-400. And again the body mileage is just under 60,000. I've used 20D's with higher mileage and not seen the problem with them.
I'm going to send the body into Canon for a clean and check and also ask them to out the noise thing .. it could be related to the electronics somewhere.
Thanks again for the replies.
Mike
segasaturn
Oct 08, 2007 07:16 |  #13
Come on guys, there are no stupid questions here.
Maybe it actually does seem to be getting noisier. Does anyone have actual proof that it can't get noisier? I'd be interested in to the answer to the OP question myself. This is a great question, and a much fresher one than the usual "40D for $650! Is this is scam?" threads.
gjl711
Oct 08, 2007 09:32 |  #14
mmahoney wrote in post #4083981 (external link)
Any clues?
Thanks,
Mike
Noise comes from the electronics on both the sensor and also the associated electronics. As electronics age, oxidation between the various connections such as the pins of the sensor and the connector, and various other connectors, can increase in resistance thus introducing more noise. In addition, due to substrate migration and crystalline changes that occur in just about all capacitors the various components of the chips themselves can change characteristics which can easily introduce more noise than when new.
So maybe it’s time to tell the wife that due to crystalline changes and substrate migration, you need to upgrade your camera. :)
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
RedHot
Oct 08, 2007 09:54 |  #15
Are you sure your new 20D image files are properly exposed? He did not post any example images. I doubt Canon will find anything wrong with his camera.
1,602 views & 0 likes for this thread, 13 members have posted to it.
2801 guests, 162 members online
