Thread started 09 Oct 2007 (Tuesday) 13:13
focus lock 400d
safetyman
Oct 09, 2007 13:13 |  #1
I used to lock the focus on my Minolta dimage A2, by swtching to manual focus on the lense after partially depressing the shutter button. Can this be down on the 400d without causing damage?
fz_za
Oct 09, 2007 14:26 |  #2
Hi safetyman
I don't really see why this would "cause damage". Wear and tear on your AF switch, maybe, but no real damage to your camera. Let's see what the others think. I don't think there is any other way to focus lock other than to keep the shutter button depressed halfway.
40D, 17-55mm f/2.8 IS, Sigma 30mm f/1.4, 70-200mm f/2.8L IS, 500D Close-up Lens, Speedlite 430EX with Demb Flash Diffuser Pro
B+W UV Haze, B+W Circular Polarizer | Lowepro Computrekker AW
Lightroom 2
gooble
Oct 09, 2007 14:31 |  #3
Set Cf.4 to 1 and you can focus with the * button instead. Problem solved.
DDan
Oct 09, 2007 14:36 as a reply to  @ fz_za's post |  #4
Check out custom function 4. Set it to 1 and you can use the * button to focus.
Gooble beat me to it.
DansRacePhotos.com (external link)
Dangerous Dan
fz_za
Oct 09, 2007 14:41 |  #5
Whoops :oops: I'm still new to CFns so I forgot about that one! Good to know!
Lightroom 2
rockfordhx
Oct 09, 2007 15:03 |  #6
currently my * button is my exposure lock. If I use the Cf.4 function will I loose my exposure lock?
http://www.nathan-photo.com (external link)
DDan
Oct 09, 2007 15:08 |  #7
rockfordhx wrote in post #4095316 (external link)
With Cf.4 set to 0, the * button overrides the AEL provided by the half press of the shutter button. With Cf.4 set to 1 the only AEL is the half press of the shutter button.
Dangerous Dan
rockfordhx
Oct 09, 2007 15:15 |  #8
Thanks DDAN that is what I was afraid of
safetyman
Oct 10, 2007 03:28 |  #9
Thank you all for your replies. I will try cf4.
1,542 views & 0 likes for this thread, 5 members have posted to it.
focus lock 400d
1794 guests, 117 members online
