I need some suggestions or hints in order to enable this function.
I selected EF D ; however, when I looked through the viewfinder I didn't see the grid at all so what am I doing wrong
ione Senior Member 358 posts Joined Sep 2007 More info | Oct 10, 2007 13:12 | #1 I need some suggestions or hints in order to enable this function.
gasrocks Cream of the Crop 13,432 posts Likes: 2 Joined Mar 2005 Location: Portage, Wisconsin USA More info | Oct 10, 2007 13:18 | #2 |
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Oct 10, 2007 13:18 | #3 It's not a function to put a grid on the screen. You need to buy the EF-D screen to get the grid lines. The function then tells the camera how to adjust metering for that screen. Jon
rang Goldmember 1,644 posts Likes: 6 Joined Jan 2007 More info | Oct 10, 2007 13:24 | #4 Jon explained it right. Lotsa stuff, running outta room and a wife...I keep looking at her and wondering???
Oct 10, 2007 13:39 | #5 oh thanks I was getting all excited since my first try to enable the grid I went through the other function in the main menu, later I found out that is was only applicable on LiveView.
I got another dumb question, so let's say that I buy the screen with the Grid. In order to enable I have to set the CF. I was and maybe I am under the impression that once you put the screen the grid lines will be shown
grinchy Senior Member 942 posts Joined Jan 2007 Location: Central Florida More info | Oct 10, 2007 17:41 | #7 ione wrote in post #4101910 I got another dumb question, so let's say that I buy the screen with the Grid. In order to enable I have to set the CF. I was and maybe I am under the impression that once you put the screen the grid lines will be shown you will see grids instantly once you put ef-d in your camera...then all you have to do is go into your settings and select ef-d option.. Body:
Ok now I understand it better, well I guess I need to shop around....
| Latest registered member was a spammer, and banned as such! 2844 guests, 162 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
