Thread started 10 Oct 2007 (Wednesday) 19:36
How do you focus at night???
AberyClark
Oct 10, 2007 19:36 |  #1
I've been experimenting with my XTi at night (tripod and built in flash). The autofocus will not latch on to something sometimes and will not allow me to take picture (I'm usually in TV mode). I can take one in manual focus mode...but I cannot see to focus. The flash burst is not long enough to give me time to focus. Please help...there must be a way. I have a Rebel XTi and 17-55IS lens.
Abery Clark
www.aberyclark.com (external link)
braduardo
Oct 10, 2007 19:50 |  #2
Manual focus without the flash. The viewfinder is pretty small, but try to find some light in an area that you NEED to be in focus, and work based on that spot.
:rolleyes: ----Brad---- :rolleyes:
www.nybergstudio.com (external link)
40D: EF 17-40 f4 L ---- EF 70-200mm f4 L ---- EF 50mm f1.4 ---- EF 85mm f1.8
ben4633
Oct 10, 2007 20:42 as a reply to  @ braduardo's post |  #3
Sometimes depends on what you are taking a picture of. If using a flash the flash will fire pre flashes to light up subject to focus off of. When not using a flash sometimes the subject is far enough away where focusing to infinity to work. Other than that you have to find something that is somewhat lit to manually focus to. Hope this helps.
Canon 7D - Canon 50D - Canon 28-135 IS - Canon 580 EXII - Canon 15-85 - Canon 10-22 - Canon 70-200 IS 4.0L - Canon 400L 5.6
http://www.flickr.com/​photos/aaronbphotos/ (external link)
Trvlr323
Oct 10, 2007 21:11 as a reply to  @ ben4633's post |  #4
Sometimes at night for macro or objects that are reasonably close, I'll light up a spot with a flashlight to get an AF lock.
Sometimes not taking a photograph can be as problematic as taking one. - Alex Webb
JackProton
Oct 10, 2007 21:53 |  #5
If you're trying to focus on something relatively close, the AF assist light bursts from the built-in flash should work. If its something too far for the AF assist to help, the flash probably isn't going to work very well anyway. Though I suppose you could try one of those crazy bright rechargable spotlights you can pick up at Target, etc.
Depending on what you're shooting, you could try just using a tripod and long exposure and manual focus on something visable at roughly the same distance as the subject.
XPHALCON
Oct 10, 2007 22:29 |  #6
If you have the luxury of having a speedlite (480EX, 580EX), the speedlite will emit an infrared light to assist in auto-focus. Also, as mentioned earlier with manual focus, you can judge the distance visually (say subject is about 10 feet) and then rotate the focus ring until 10 feet is lined up with the focus line. Hope this helps.
I wish I had a witty cliche' like everyone else.
http://www.flickr.com/​photos/39512042@N00/ (external link)
mikeassk
Oct 10, 2007 23:29 |  #7
AberyClark wrote in post #4102601 (external link)
Are you doing long exposures( 20 second ish?).
If so than stop down as much as possible= f22 ish and just manuall focus until you can get some decent results. If your going for a static night shot with a flash and movement than good luck haha.
Stuff
Chris ­ Stewart
Oct 10, 2007 23:35 |  #8
if possible get a friend to stand next to the object your photographing and flash a torch directly at you.
http://www.myspace.com​/southozstew (external link)
geekyrocketguy
Oct 11, 2007 00:17 |  #9
Put one of the AF points on the brightest part of the photo. I've also used a flashlight to focus before...
I don't try to intimidate people with my gear.
My Photography Site (external link)
ironchef31
Oct 11, 2007 01:09 |  #10
If you know the distance to the subject, your 17-55 has a window on the top with a distance scale. Try using that instead of the view finder. If you need maximum dof, figure out what the hyperfocal distance value of the focal length you are using. This is old school. When cameras looked like geekyrocketgy's avatar.
Ken
30D, 18-55mm, nifty 50, 17-55 F2.8 IS, 70-200 F2.8 IS
I tried to bounce my flash off the ceiling once. Left a mark on the ceiling and broke my flash.
rowdyred94
Oct 11, 2007 07:07 |  #11
Chris Stewart wrote in post #4103770 (external link)
Say what, now? What will that do besides blind him?
~ Clint :: Galleries (external link) ::
Michael
Oct 11, 2007 10:16 |  #12
rowdyred94 wrote in post #4104805 (external link)
Yeah. What? I would rather not have a bright light shone down my lens. Not cause it would hurt the lens, but my eyes would be sore :(.
Michael
Gatorboy
Oct 11, 2007 10:52 |  #13
Get a flashlight to shine on the area you want to focus on.
Dave Hoffmann
Pixel9ine
Oct 11, 2007 11:04 as a reply to  @ Gatorboy's post |  #14
Laser Pointer.
Andre B :: gearlist
www.pixel9ineexternal link.com
ipschoser1
Oct 11, 2007 11:08 as a reply to  @ Pixel9ine's post |  #15
I use the flashlight method, but when the autofocus locks, I switch the lens to MF mode. That way, you can recompose or shoot multiple exposures.
http://www.flickr.com/​photos/district_histor​y_fan/ (external link)
3,577 views & 0 likes for this thread, 23 members have posted to it.
2723 guests, 145 members online
